KONI FSD R53 to R56?
hi just want to ask if i can use the koni fsd of my r53 to my friends r56? im using koni fsd with jcw springs. I got a set of KW V1 from r56 and i was able to use it with my r53 just swapped my IE Fixed Camber Plates in the front and removed spacer/washer in the rear where you put the bolt.
My friend would like to try if the koni fsd/jcw spring will fit his r56 if we put the r56 top mount and the washer/spacer at the rear. thanks
Vendor
Yes physical you can make them all bolt in, now how's the ride and performance? That will be the unknown.
You will need these rear shock spacers to install the rear shocks.
http://www.waymotorworks.com/wmw-rea...k-spacers.html
Racingguy04
Suspension
22
10-18-2015 07:06 PM
Emnotek
10-02-2015 08:43 AM
