MINI Tool Kit
I'm not sure what you're wanting to accomplish. My thinking is you can have a complete set of tools and if something breaks those tools won't do you a bit of good if you don't have the part needed to replace the broken part. I'm comfortable with my tools at home in my tool box and my cell phone and credit card in my pocket when I'm on the road. In addition to that I do have Mini road service and a factory warranty.
There are several reasons to have a minimal tool kit in your car. The convertible I have has a way to disconnect the top from the motor mechanism in case you need to raise the top in an emergency if the top motor or mechanism breaks. It's a Torx wrench I believe and it would be handy to have another one. The car comes with one, but it is buried in the bottom of the boot. Unhandy if you have the car packed on a trip and an extra one is nice.
The fuses are kind of hard to pull out. I have a little fuse puller that helps a lot. I've had to disconnect batteries for one reason or another on the road. One time it was to reset the ECU on a ford so the car would start. Another was to clean the terminals so the car would start.
I've replaced belts and hoses on the road. I don't think I will be replacing the belt on my MINI as it is very difficult to do, but a hose is a possibility. There are many reasons to carry a small tool kit in a car. Yes we have cell phones and MINI roadside service, but here in the wilds of New Mexico and Colorado cell phone service can be spotty or none. It could take hours to get road side service. There is a stretch of road on the Navajo reservation that there is no cell service and in fact no land line for 30 miles.
Chaco Canyon in NM has no cell service and in fact the visitor center has no landline, they have to use a satellite phone. I would much rather tighten a loose bolt or electrical connection then wait hours for roadside service with my top stuck down in the rain with a dead battery at Chaco Canyon.
I use to drive on the road for work and I always carried an extra belt, both hoses, a can of oil and antifreeze.
I carry
needle nose pliers
adjustable wrench (crescent)
vice grips
screwdriver handle with tip set (includes common torx) (torx has its own size "T")
leatherman tool
several feet of decent solid core wire (can tie up a drooping muffler)
small bundle of zip ties assorted sizes (can replace most hose clamps)
leather or mechanic's gloves
small pkg assorted fuses
if a MINI and not using run flats any more a DYNAPLUG and small pump
in addition to flash light and pressure gau' in the glove box.
needle nose pliers
vice grips
leatherman tool
You should have a small tool set already in the trunk section, with the runflat option. Have you checked whats in the boot already ?
Other then that above comments have some good info. The other thing I would get is a can of fix a flat or a portable tire infiltrator .
04-28-2016 06:10 AM
04-28-2016 06:09 AM
jmminics
04-25-2016 02:23 PM
