Liqui Moly oil weight?
I run 5w40 Liqui Molly. I based my choice of oil weights on 1. Did it meet mfg's spec 2. The temperature & climate 3. Cost vs availability and 4. frequency of changing. 5w/40 is best for me. If I lived in Alaska, I would probably use 0w/30. I change my oil every 3000 to 6000 miles . I buy it on Amazon and it's delivered, always buying a new five gallon jug right after changing the oil. But that's just me...you're mileage may vary...
I am running Liqui Molly : Molygen 5w-40 right now on both my MINIs. Not an issue.
The number preceding the "W" rates the oil's flow at 0 degrees Fahrenheit (-17.8 degrees Celsius). The second number is the grade of the equivalent single-grade oil that describes its viscosity at 100 °C (212 °F).
If you're running the car hard I would opt for the 40 weight, if you're after fuel economy like the manufacturer is then the 30 weight is the choice.
Not really hard...but i would switch to the 5w-40 in the warmer months
10-26-2017 02:43 PM
10-26-2017 02:42 PM
09-18-2017 06:57 AM
