NGK plugs are for BMW/MINIs, Champions are for _______________
I just had the plugs changed out on my new-to-me 2018 F60 MINI Countryman which has the BMW B46 engine. It had Champion plugs in it (which I didn't know) but I had noticed the engine had a small hesitation under small part-throttle application. I have a BMW/MINI code reader and it showed no misfires, etc., so I suspected plugs. 4 brand new NGK brand BMW OE plugs later and the car pulls smooth as butter at any throttle position. Is it true what they say: Champions are for lawnmowers and NGK are for BMWs?
Were the old plugs unusually worn? Or the car high mileage? Unusual to have plugs be an issue after only three years. Normal replacement interval is 60,000mi.
Unless the car has a LOT of miles on it, the plugs you removed should have been the ones installed by the factory. Note, though, I said ”should”. I can’t find any evidence online that BMW/MINI ever uses Champion brand plugs in their gasoline engines. I suspect that the previous owner replaced plugs at some point and cheaped out. (NGK and Bosch, the usual BMW factory choices, are more expensive.)
Did you get service records with the car?
Eurothrasher
07-07-2008 04:40 PM
turboexempt
31
03-10-2008 09:59 PM
