Mushrooming Strut Tower NEED HELP!!!
I just installed my CAI on Sunday on my GP, when I noticed that the passenger strut tower mount has mushroomed. Ok I want to get it fix obviously, but my question to all that have R53's, what should I buy to reinforce and make sure it doesnt happen again? Thanks for all advice.
Strut tower plates / defenders (M7, Cravenspeed, VIP) will provide some measure of protection. For even better reinforcement, camber plates will do nicely. Ireland Engineering and Vorshlagg (sp?) are both well regarded camber plate manufacturers.
BTW, your photo does not show strut tower damage, it does show top hat damage to the rubber seal. That fix is a remove and replace of the part at about $90 each through PelicanParts. It would also be the part replaced by camber plates.
Strut tower mushrooming is the actual bending of the sheet metal around the three studs/nuts that mount the strut to the sheet metal. It is not obvious from the photo whether or not your car has mushrooming.
As OPC points out your car appears to have a torn top strut bushing which is a common problem.
My car had mushrooming and torn bushing so I replaced the top sturt mount with H-Sport (Hotchkis) adjustable camber plates. The adj camber plates have a metal bearing instead of the rubber bushing and a thick metal plate to eliminate the mushrooming. However, adj camber plates are not for everyone because they add a little noise/harseness, are expensive, and the adjustability may not be needed.
A good alternative is fixed camber plates. They have a little more durable rubber, are a little thicker to help prevent mushrooming, and increase the negative camber by 1.25 degrees which improves handling. They are also about the same price as the stock rubber bushing.
http://www.waymotorworks.com/ireland...e-r50-r53.html
Here is a easy fix.
1. get strut mount as OPC said.
2. get strut reinforcement plate. ( M7,VIP, or way's )
3. remove strut.
4. put the new reinforcement plate on top of mushroomed tower.
5. place a thick block of wood over plate and pound back down.
( the plate will cause the tower to stay in shape as it goes down)
6. when back to shape where the new mount bolts stick streight up through
put the struts back in..
All fixed. should take about 1.5 hrs max if doing yourself for first time.
3. remove strut.
If you decide to remove the strut yourself, you will need a couple special tools:
1. Spring compressor, Harbor Freight has them for about $15.
2. Spark Plug socket with hex top to get top strut nut off and on (need to stick allen wrench through socket and turn socket with a wrench).
Do you really need a spring compressor to remove the strut? doesn't it come out as one unit?
