How To R55 / R56 MCS Clutch Bleeding Instructions
Old 03-29-2011 | 09:31 AM
palgiere's Avatar
palgiere
Smile R55 / R56 MCS Clutch Bleeding Instructions
MINI Cooper R55 / R56 Bleeding the Clutch
(passing along my my notes. hope they help)
Here is how to prime the clutch. The whole process should take under 20 minutes.
This is how the system works - The clutch operates using brake fluid. It draws off the brake fluid reservoir via a black tube on the side. Fluid flows from the reservoir into the cylinder above the clutch pedal (when there is a negative pressure). Then when the pedal is pushed the pedal cylinder pushes fluid through the tube into the clutch slave cylinder which activates the clutch. The clutch slave cylinder is attached to the transmission on the front, lower, left side. It is a black plastic cylinder that has the bleed valve. Look under the driver side head light a little inboard. When there is air in the system simply pumping the clutch does not prime the system. It just moves a little fluid back and forth. And pumping until your arm falls off will not do anything.
Step (1) Attach a clear 3-foot tube to the bleed valve. Keep the tube elevated to keep air out. Place other end in a plastic bottle to catch fluid. Note: The clutch slave cylinder is after the bleed valve and therefore difficult to remove air. The method described here will allow you to push fluid into the clutch slave cylinder.
Step (2) Pull the pedal up, open bleed screw, push pedal to the floor, tighten bleed screw. Then very slowly pull clutch pedal up. This allows the fluid to flow into the petal from the brake fluid reservoir. Repeat the process (up, open, floor, close, pull up slowly). You should see a mixture of air and fluid flowing into the tube. Keep repeating (5-10 times) until the fluid flowing in the tube is void of bubbles. Note: Make sure that the brake fluid in the reservoir remains above the clutch passage.
Step (3) With the bleed valve off you should start to feel resistance when you pump the clutch pedal. If the pedal is soft you have air in the clutch slave cylinder (or a leak in the system noted by a brake fluid puddle).
Step (4) Prime the clutch slave cylinder. Make sure the clear 3-foot tube that is attached to the to the bleed valve is still filled with fluid. Empty out the last 4" from the end. Clean the end with a lint free towel and soap and water. (be careful not to get anything into the tube).
Step (5) Blow into the tube (or attach a small pump) to push fluid back into clutch slave cylinder. Try to push at least 2 feet of fluid back into the system. But stop before emptying the tube. Then close the bleed screw. (be very careful not to get any fluid into your mouth)
Step (6) With the bleed valve off pump the clutch pedal. You should feel close to normal resistance at the top of the pedal.
Step (7) Clear any air that you pushed out of the slave cylinder by repeating Step (2) a couple of times (up, open, floor, close, pull up slowly). Stop when you have pushed out more fluid than you blew back in.
Step (8) With the bleed valve off pump the clutch pedal. You should feel normal resistance at the top of the pedal. If not you may need to repeat the process. This works for me the first time.
Grip Grip (03-19-2018)
Old 10-28-2012 | 09:02 AM
MiniMoic's Avatar
MiniMoic
I think this is a great how to, thanks for posting.
Is the air in the system another possible cause of a "hiss" when the pedal is free?
Old 10-28-2012 | 08:05 PM
palgiere's Avatar
palgiere
Thanks. Yes, air in the system will make noise. It could be the cause of your "hiss." The input cylinder clutch (attached to the peddle assembly) could have sucked air from the brake fluid reservoir. Or you could have a that let air in. You may want to bleeding the clutch to see if the noise goes away.
Old 10-28-2012 | 09:37 PM
MiniMoic's Avatar
MiniMoic
Makes sense, in another post, I asked this same question about the noise. I took my car to a new shop near home and asked them to bleed the brakes. They pulled out all the oil from the reservoir, but I do not believe they knew about the clutch line, will try to follow your how to and report back...
Old 12-09-2014 | 01:33 PM
automan21's Avatar
automan21
Has anyone done this recently, with pics?
Old 05-21-2020 | 12:36 PM
Boostedmini420's Avatar
Boostedmini420
Sorry for kicking a long dead horse but to clarify when you say "with the bleed valve off" do you mean closed or removed from the slave cylinder?
madcanvis (06-08-2024)
eliseo1981
01-28-2021 03:45 PM
08-19-2015 01:51 PM
08-19-2015 09:22 AM
08-19-2015 09:22 AM
WayMotorWorks
08-04-2015 02:47 PM
