How To Trunk lid grip button not working – DIY
#26
hello.
The middle cable power the trunk lid bulbs and the micro switch itself. Sounds like you have a break in the short connection on the grip side. Check the interior wire for crud and corrosion, also the metal tabs that hold the bulbs can corrode it the plastic clear lens covers fell off or did get moisture past the lens.
#27
#28
Trunk Lid Handle Grip and Trunk Lid Lock
I just joined this group.. this is my very first post so I hope I am doing this right. I just replaced my Trunk Lid Handle on my 2007 Mini. The rubber handle was rotted out so I bought the entire piece to replace. I made the connections and screwed everything back in place. I tested the lights.. it worked... I tested the trunk opener on my key fob.. it worked. I used the handle grip to open the hatch.. it worked. Then I locked my car with the Key Fob.. everything locked.. except my hatch. I took everything apart to make sure I installed it right .. checked everything again... and had the same problem. The ONLY way I can get my hatch to lock is to have one of my key fobs in the ignition, then with the other key fob in hand.. lock the car and then the hatch locks. IF I take that key fob out of the ignition and try to lock the car.. all locks with exception of rear hatch. I called the dealer and was told I now need to purchase a Trunk Lid Lock and that is what my problem is. I am writing in hopes that someone on this panel knows if this is correct or if I am being told something so that I have to shell out more money. Does ANYONE know why this is happening and if there is another option? Thank you in advance everyone!!
#29
Great
#30
ECSTuning,
today my trunk button was working ok, but (I don't know why) today I was opening the trunk by touching the button and nothing. I checked the car was totally unlocked (ok) and then I touched the button again. BUT I could hear a noise like some plastic under the button crashed
Now the button is still not working and it feels different (like less resistance).
I'm sure it was too much pressure with my hand and something is wrong inside the button.
I have the trunk lid grip in my hand and I was checking how to access the button, but I can see now, here, in this thread that the button is not accessible (I suspected that).
I'm searching for a new button (I need an entire trunk lid grip), and I was checking your links.
My car is a Mini Cooper 2010 non-S.
P/N: 51132753603
I was searching for the black one (actually mine is black, thanks to plastidip )
It is for my car model? (Specs don't say about gen nor year):
https://www.ecstuning.com/Search/Sit..._Grip/ES78252/
Thank you!
P/N: 51132753603
Thank you!
#31
#32
ECSTuning,
P/N: 51132753603
Thank you!
P/N: 51132753603
Thank you!
Hello for Gen 2 MINIs its 51132754240 for the primed ready to paint or plasti dip, comes with the light bulbs and lens already to install.
https://www.ecstuning.com/Search/SiteSearch/51132754240/
#33
#34
#36
You're very welcome. If you need anything else, I'm here to help.
888.280.7799 | 6am - 5pm PST
#37
Welcome , i have fixed these on the gen 1 and Gen 2 MINIs and my own personal car, in Gen 2 you can do a transplant of the primed one of your old cover to save the outside painted part of design, Linked diy above as well as all the other options like Carbon fiber and Chrome. On Gen 2 MINIs they did not come in black, That was gen 1 MINI in black primed look and in Gen 3 MINI it comes in shiny black.
If you want to know about trunk grip handles we are the place.
#38
#39
Button is working!
Fortunately yesterday I discovered that the button works!
It seems there is something wrong with the button but if pressed in the center (a little deeper than some days ago) it works perfectly.
Maybe the button has always locked by something and now it is unlocked. Or maybe just I broke something that is not serious.
I still like the F56 trunk lid handle (abs plastic cover) in glossy black.
#40
Welcome.
https://www.ecstuning.com/Search/SiteSearch/3m_Wrap/
#41
#42
+1 Nice write up. And a great job on the walk through.
Yes the part number for just the Trunk lid grip base backing part does not come up. Its only as one full part. Popping the rear cover off is great for people who want to transfer the internals and save on painting the new one.
Trunk Lid Grip - Primed Part number 51132754240
#43
Yes.
#44
2006 convertible. The rear hatch was not working at all. I checked the function of the switch with a meter and the motor by jumping. Both worked fine. Based on a tip in a previous message, l thought it might be a bad wire in the run between the hatch and the body. So I bypassed the brown/grey and green/grey wires and voila; back in operation! The wires are of very small gauge which may explain their demise from the opening and closing of the hatch.
#45
Yep, you have a break in the wire harness. Did you tap in a new wire, was it corroded or just a break ?
Gen 1 is here :
https://www.northamericanmotoring.co...ght-cover.html
Or here:
Gen 1
51247114535
https://www.ecstuning.com/Search/SiteSearch/51247114535/
Gen 1
Here is the Gen 1 R50 R52 R53 License plate grip :
Here is the grip handles if you need them because the unit is damaged, not just the lens.
Dependent on your options and version. The housing is rear handle.
"Chrome" version. 51137074020
http://www.ecstuning.com/Search/51137074020/ES78095/
"Primed" Version: ( for painted rear trunk grips ) 51137075582
http://www.ecstuning.com/Search/51137075582/ES78098/
"Black" Version: ( for basic or black rear trunk grips )
http://www.ecstuning.com/Search/SiteSearch/51137167530/ES78252/
Trunk Lid Grip - JCW Carbon Fiber 51130395503
http://www.ecstuning.com/Search/51130395503/
Here is the Gen 2 R56 R57 R58 R59 + License plate light cover:
Lens themselves: 51132756227
https://www.ecstuning.com/Search/SiteSearch/51132756227/
There is a primed version: Part # 51132754240 ( people transfer there painted cover to the new front part of the handle. )
*** We have aftermarket versions in Bremmen Parts now**
http://www.ecstuning.com/Search/SiteSearch/51132754240/
The chrome version.
Trunk Lid Grip - Chrome Part # 51132753603
http://www.ecstuning.com/Search/SiteSearch/51132753603/
There is also a carbon fiber version.
JCW Carbon Fiber Lid Grip 51130415377
http://www.ecstuning.com/Search/SiteSearch/51130415377/
Link to great DIY for the Gen 2 MINI version.
https://www.northamericanmotoring.co...rking-diy.html
Gen 1 is here :
Or here:
Gen 1
51247114535
Gen 1
The chrome version.
#46
I just bypassed with lamp cord outside the rubber boot connecting the trunk lid to the body. I didn't bother to open the rubber boot to see the cause of the problem. The other functions fed by the wires inside the boot (lights) were working fine so I didn't want to bother them. I don't think corrosion was the issue because the car is not exposed to the elements and there are no other signs of corrosion. Thanks about letting me know I have Gen 1. So I have provided the same message in that forum.
#47
#48
U can just replace the switch
[QUOTE=RandyR90S;3791230]Replace and Install
Now that you know the handle switch is at fault, here’s how to replace and repair….
Replace the trunk lid grip
Parts/tools:
Mini Cooper part 51132753603:
Handle, trunk lid, with lamp unit Chrome line exterior
Unfortunately you can't order just the switch - it appears to be molded into the housing.
This is the part !
http://new.minimania.com/part/NMX860...nZ9RoCIZfw_wcB
Lot of work tho to remove the old but install of new was easy.
Parts/tools:
This is the part !
#49
I had ordered the CF , once I got the thing apart i noticed the plug was halfway in. Pushed in and out a few times to clean the contracts up. Worked fine.
Changed it out to the CF since I had it in hand.....
Others might want to take it apart first to see if its a simple fix sounds like..
#50
Hi All,
Our button release stopped working and googling brought me to this thread. Once I tried the helpful trick of checking the wiring (will only work when the car is unlocked) with a paper clip, I knew it was the switch itself and not a wiring fault. So I decided to take it apart to see if it was fixable. I didnt have to worry about breaking it since it was junk anyway.
What I found was there is a small micro switch with a cover/spacer thing on there which presses the microswitch when you depress the rubber button. This plastic part had come away from the microswitch so the button couldn't activate it. So I glued it back on with no nails and its all working again.
pilotart (01-27-2018)
