How To Trunk lid grip button not working – DIY
Old 11-23-2022, 04:38 PM
Lex2008's Avatar
Lex2008
Lex2008 is offline
Maybe the motor for the lock mechanism is dead.
Did you check the fuse?
  #102
Old 11-26-2022, 09:42 PM
tango5432's Avatar
tango5432
tango5432 is offline
I checked all the fuses. I replaced F23 and F 37
  #103
Old 11-27-2022, 06:39 AM
Lex2008's Avatar
Lex2008
Lex2008 is offline
And.... It didn't fix the issue? Unplug the motor and apply 12 volts and see if it clicks... So you know if it's the motor versus the circuit.
  #104
Old 11-28-2022, 04:21 AM
tango5432's Avatar
tango5432
I removed the motor and direct wired it to the battery. It worked all 5 times I tried. All the wiring checks out all the way to the plug. Something is wrong from the boot/trunk to wherever it gets power. All the wiring in the rubber sleeve is intact.
Thank you for taking the time to answer this thread.
  #105
Old 11-28-2022, 06:07 AM
Lex2008's Avatar
Lex2008
Lex2008 is offline
Ok so it's not getting 12 volts... Did you check the relay?
I use a LoadPro which loads the circuit to see if it truly is carrying enough voltage. Any minor corrosion will cause a circuit failure even though it shows continuity.
  #106
Old 11-28-2022, 03:12 PM
tango5432's Avatar
tango5432
I will test tomorrow. Thank you!!!
  #107
Old 05-16-2024, 07:49 AM
texasman's Avatar
texasman
texasman is offline
hi!
I have same problem like you (button was change, light working). Did you find problem? Do you find fuse for trunk button?
  #108
Old 05-16-2024, 08:10 AM
atombaum's Avatar
atombaum
atombaum is offline
In my case (2015 Countryman), the solution was to replace the trunk/tailgate bumper antenna.
Search for: Mini Cooper B1MISA-Bumper Antenna 61-35-6-922-212.
  #109
Old 05-16-2024, 08:38 AM
ECSTuning is online now
Received 2,091 Likes on 1,865 Posts
Yep thats the one that fits under the bumper for people with comfort access. Once you fix that the comfort access will work and unlock the tail gate. Most MINIs dont have the CA option. Also Make sure if you have CA that the battery in the key fob remote (second one) is new.
https://www.ecstuning.com/b-genuine-...a/61356922212/
  #110
Old 08-08-2024, 10:29 AM
Here are the male plug and wires if that side is bad on the harness. Works on Gen 1 and Gen 2 MINIs.
https://www.ecstuning.com/b-genuine-...138377072~oem/
And
https://www.ecstuning.com/Search/Sit...h/61130005197/ x 3 for the cars with 0.2-0.5m pins
or
https://www.ecstuning.com/Search/Sit...h/61130056960/ x 2 (2 pins on one wire) for pin 0.75mm size.
  #111
Old 08-08-2024, 10:41 AM
Lex2008's Avatar
Lex2008
Lex2008 is offline
And
or
Whats this for? I'm confused.
  #112
Old 08-08-2024, 11:51 AM
Just had a person call in and they asked for the connection side as these plugs get damaged and corroded. I dug around and fitted the plug to a Gen 2 MINI trunk lid grip and it fits. Its not on the MINI ETK as a part that works, Just for the Gen 1 MINIs. Hopefully that helps repair some of these.
  #113
Old 08-08-2024, 12:24 PM
Lex2008's Avatar
Lex2008
Lex2008 is offline
oh thats awesome.
This kind of stuff is harder to find on automobiles. In the truck world they sell every imaginable pigtail and connector because guys run their trucks for 20-30 years plus.
ECSTuning (08-08-2024)
alexh1
12-28-2017 06:58 AM
RandyR90S
05-14-2014 11:42 AM
richardsperry
04-22-2014 01:47 PM
Mudnut
08-20-2013 06:06 AM
bobbyharr883
02-05-2007 06:46 PM
Quick Reply: How To Trunk lid grip button not working – DIY
