How To Maintenance :: Oil Change How-To
Old 08-18-2008, 05:36 AM
ltphoto's Avatar
ltphoto
ltphoto is offline
Using this thread for a guide I did my first oil change yesterday. Everything went just fine until I was filling it up again with oil. While pouring I noticed that I was using 10W-30, not 5W-30. Checked the other bottles already emptied and they were the same. Must have had a brain fart at the store and picked up the wrong ones. Here's my question. Any implications of using 10W-30? I'm guessing not an issue in the Summer, but should I change it out before the cold weather gets here?
  #152
Old 08-18-2008, 05:39 AM
Detroit Tuned's Avatar
Detroit Tuned
Detroit Tuned is offline
Vendor - 15 Years
it will not hurt anything. run it since it's already in there and just swap back on the next change.
Chad
Detroit Tuned.
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
  #153
Old 08-20-2008, 07:55 AM
Speedwing's Avatar
Speedwing
Speedwing is offline
Update ..... After my purple MINI decided to up-chuck 1 quart of royal purple 5W-30 due to a seperated into two parts O-ring ..... the old O-ring is holding fine and the car runs so smooth on the new Royal Purple synthetic. I mean it is absolutely different than the stock castrol synthetic. It no longer rattles slightly at start-up. The engine feels smoother and seems to have a bit more power .... because I am downshifting less on the same hills. Gas mileage also seems to have improved "slightly". More time will tell.
Use lots of new oil to lube your O-ring and NOT WD-40!
  #154
Old 08-20-2008, 10:30 AM
thulchatt's Avatar
thulchatt
thulchatt is offline
Glad things worked out and don't be to hard on yourself on the WD-40, it seems most people think it is a lube.
It is actually more of a solvent than lube. WD stands for Water Disperant, 40 is simply the 40th formula they developed. (Could be folk lore but I remember hearing this someplace from the developer.)
  #155
Old 09-02-2008, 12:51 AM
jollyroger927's Avatar
jollyroger927
jollyroger927 is offline
WD-40, as ive heard from many, many sources, eats away at rubber and o-rings. Just want to throw it out there since it seems like some are choosing that first for the o-rings. I would just use some regular oil or I think 100% silicone oil is also alright.
  #156
Old 10-23-2008, 07:30 PM
MrDimple's Avatar
MrDimple
MrDimple is offline
Thank you RANDYBMC you did a great job way back on oil change article, very good.
  #157
Old 10-28-2008, 06:00 PM
chrwilliams's Avatar
chrwilliams
chrwilliams is offline
AM/Randy:
Over the weekend I changed my oil and re-set my service indicator. Thanks to all.
TIA
  #158
Old 10-29-2008, 10:24 AM
MrDimple's Avatar
MrDimple
MrDimple is offline
To itphoto.............Just to let yo know not to be alarmed by 5-30 vs 10-30.
The 30 is what the oil IS 30wt. the 0, 5, 10 15 nomenclature fefore the 30wt. means what the oil pours like at a freezing temperature, ie, 10/30 will pour like 10 wt. at freezing temperatures. I personally use 0/30wt. year round on mine with no reservations. I use Amsoil signature 0/30 and I love it, I get 5% better gas mileage with it "pays for the oil and the Dimples I put on the car".
  #159
Old 11-21-2008, 03:21 PM
superfly5203's Avatar
superfly5203
superfly5203 is offline
how do you reset the oil clock thing. that tells you how many miles to go till oil change?
  #160
Old 12-02-2008, 04:31 PM
NTACTUALSIZE's Avatar
NTACTUALSIZE
NTACTUALSIZE is offline
glad to see that you guys can do a good how to on doing an oil change as oposed to the r56 how to which is actually shows you how to drain your trans and double fill the engine
  #161
Old 12-15-2008, 01:00 PM
MiniMite's Avatar
MiniMite
MiniMite is offline
How do you reset your idicator after you do your oil change i am having trouble resetting the idicator part after you do the oil change?
please help asap
  #162
Old 12-15-2008, 07:11 PM
Eric_Rowland's Avatar
Eric_Rowland
Eric_Rowland is offline
please help asap
https://www.northamericanmotoring.co...524-post2.html
Originally Posted by edlfrey
Service Reset:
!)Push-hold Trip Button (TB)
2)Turn key to position 1
3)Continue to hold (TB), the number 15A will show to the teft of the milage
4)Release (TB) for 3 sec and then hold (TB) again
5)In about 5-8 sec RST will show in the left corner
6)Release and then hold again "15000" will show, press and release
7)Car is now reset to the 15,000 service - (has completed 10,000 mile service) and will count down from 15,000.
I have followed this procedure up to step 6 with 15000 showing but did not reset. I'm only at 2700 miles now but changed oil at 1250. Note: the 15A and RST are a little difficult to read because of Capital and Small letters.
Good luck :smile:
  #163
Old 12-22-2008, 11:14 AM
MiniKJ's Avatar
MiniKJ
MiniKJ is offline
I just went through my first oil change. The toughest part was trying to get the canister cover out of/into the engine compartment. I have a 06 MCS"a", so I don't know if that's the reason due to larger size transmission on the drive side. I read some instructions of an engine damper installation that the engine position is slightly off towards the passenge side with automatic MINI. I ended up taking out and tighten the canister under the car through the lower control arm and steering knuckle. Thank "Rhino Ramp" for making this job much easier.
I also want to point out that the Bently manual has different information than the owner's manual for MCS. Bentley just says 4.7qt for oil change while the MINI owner's manual says 5.1qt. I put in 5 and a little extra qt and the level was at max.
Finally, I have a question about the drain plug. Am I supposed to torque it to 18 ft-lb?
Happy Holidays to everyone.
  #164
Old 12-22-2008, 05:28 PM
ahamos's Avatar
ahamos
ahamos is offline
Coordinator :: River City Minis
One of those measurements was probably in liters.
  #165
Old 12-24-2008, 12:09 PM
apexer's Avatar
apexer
apexer is offline
Without going into my COLD garage, I can't check my Bently manual but torque is either 18 or 25 ft.lbs. BTW: 5 quarts fills mine up.
  #166
Old 12-24-2008, 03:55 PM
Eric_Rowland
IMO, the appropriate torque is the German standard - 'guttentight'.
As long as you don't tighten it with a 2 foot lever or a impact gun, as seems to be the case with too many shops, it'll be fine.
  #167
Old 12-24-2008, 05:08 PM
Capt_bj's Avatar
Capt_bj
Capt_bj is offline
Don't over do it
Yes - note the many who've had problems getting the blasted thing out....
25 ft lbs ain't very much...... Just needs to be tight enuf to not fall out...it isn't load bearing or anything...
  #168
Old 12-29-2008, 07:58 PM
cmy's Avatar
cmy
cmy is offline
I just changed my oil for the first time, but I didn't replace the oil drain plug gasket. Should this be replaced at each oil change? Thanks Randy for the tutorial.
I did notice an oil leak however It's not bad and I think it started before the oil change. I sent the dealership an email tonight to schedule service. I have 4000 miles left on my warranty
  #169
Old 12-30-2008, 07:00 AM
apexer's Avatar
apexer
apexer is offline
Oil drain plug gasket is attached to the drain plug itself. I've never seen any info requiring changing of the drain plug gasket.
  #170
Old 12-30-2008, 08:17 AM
Crashton's Avatar
Crashton
Crashton is offline
In 48,000 miles with an oil change every 6,000 miles I've never seen a leak from the MINI's drain plug gasket. I have seen the hex head on the drain plug gradually get kind of borked up. Although I attribute that to the son of Kong tightenings it's gotten at the dealer. I keep a spare on the shelf with the oil filters just in case & look closely before reusing it.
  #171
Old 12-30-2008, 10:09 AM
MiniKJ's Avatar
MiniKJ
MiniKJ is offline
I think the 4.7qt was spot on for the MC, but for MCS should be 5.1qt. That's what I read in the owner's manual.
Heck, the most important thing is, I see the oil level up to the MAX mark on the dip stick.
  #172
Old 12-30-2008, 05:56 PM
ahamos's Avatar
ahamos
ahamos is offline
5.1qt is 4.82l, so I still hold that the conversion is what he's seeing. The issue has previously been discussed that the Bentley manual and the owner's manual are in disagreement about English vs. Metric.
Either way, 4.7 puts the mark dead-center on the stick in mine.
  #173
Old 01-05-2009, 12:01 AM
cmy's Avatar
cmy
cmy is offline
Thanks for the info. Turns out I have a coolant leak also Hopefully not a big deal. I'll find out next week
  #174
Old 01-05-2009, 01:43 PM
Crashton's Avatar
Crashton
Crashton is offline
Your coolant leak most likely is the thermostat housing. According to the tech I talked to, they all do it & it is an easy fix. Fret not you still have warranty coverage.
  #175
Old 01-05-2009, 03:08 PM
not-so-rednwhitecooper
not-so-rednwhitecooper is offline
You are supposed to replace drain plug gaskets on every oil change.
Quick Reply: How To Maintenance :: Oil Change How-To
