Stri Gauge, hottest gauge in the market now !
ALL STRI Gauges are display in PSI or Fahrenheit Unit
Introducing the new STRI Racing Gauge. Available in two different series. DSD series (stepping motor + user preset warning) and X Line series which are non-stepping motor and factory preset warning, thus half the price of the DSD series.
STRI's top of the line gauges with their many impressive functions & features make them a choice by many top professional racers and tuning shops. The X-Line is one of the latest models released by STRI. By using an advanced microprocessor the X-Line gauges are highly responsive, reliable and precise. X-Line gauges are available in two sizes 52mm and 60mm and your choice of either a black or white face with amber or white illumination.
Official Website: http://www.striracing-usa.com/hom.htm
Japan Website: www.stri.jp
DSD Series - Stepping Motor + Electronic Warning Gauge + Smoke Lens
STRI’s new DSD warning gauges offer all of the functions a demanding driver requires. Driven by rugged stepper motor, the DSD gauges inform you of your car’s vitals with extreme accuracy. Controlled by an advanced microprocessor, the DSD gauges are the latest in technology. Using the highest quality components DSD gauges will keep tabs on your car with surgical precision. . The DSD warning gauges are available in two sizes, 52mm and 60mm.
They are available in two models, the CS or the SLM series.
DSD Line FUNCTION
- User Preset Warning
- Peak Recall
- Auto Self Calibration
- 270 Degree Sweep
- Short circuit auto detect
- Sequential open / closing mode
- Dimmer function
- High brightness LED
- Light weight aluminum casing.
- All sensors included
- Mounting solution included
- Available in smoke lens - black or white LED backlight
- Available in white face - green LED back light
- Available in black face - amber LED back light
- Available in 52mm or 60mm size
Boost (2 bar) - $139.00 (electronic gauge)
PSI Unit
Boost (3 bar) - $159.00 (electronic gauge)
PSI Unit
EGT - $145.00 (electronic gauge)
Fahrenheit Unit
Oil Pressure - $169.00 (electronic gauge)
PSI Unit
Oil Temp - $109.00 (electronic gauge)
Fahrenheit Unit
Fuel Pressure - $169.00 (electronic gauge)
PSI Unit
Water Temp - $109.00 (electronic gauge)
Fahrenheit Unit
Tach - $99.00 (electronic gauge)
Voltmeter - $99.00 (electronic gauge)
X Line Series FUNCTION
- Factory Preset Warning
- 270 Degree Sweep
- Start up open mode
- Dimmer function
- Available in black face, white face or smoke lens
- Available in white or amber LED backlight
Boost - $59.00 (mechanical gauge)
PSI Unit
EGT - $109.00 (electronic gauge)
Fahrenheit Unit
Oil Pressure - $79.00 (electronic gauge)
PSI Unit
Oil Temp - $69.00 (electronic gauge)
Fahrenheit Unit
Fuel Pressure - $59.00 (electronic gauge)
PSI Unit
Water Temp - $69.00 (electronic gauge)
Fahrenheit Unit
Tach - $59.00 (electronic gauge)
Voltmeter - $59.00 (electronic gauge)
Vacuum - $59.00 (mechanical gauge)
PSI Unit
[ATI E-Pod
ATI e-Pod (replace top piece of your steering column) - $99. shipped
- hold 2 x 52mm or 2 x 60mm gauges.
- rotational cup for custom viewing angle
- clean and easy install
DSD Line FUNCTION
- Peak Recall
- 270 Degree Sweep
- Dimmer function
PSI Unit
PSI Unit
Fahrenheit Unit
PSI Unit
Fahrenheit Unit
PSI Unit
Fahrenheit Unit
- 270 Degree Sweep
- Dimmer function
PSI Unit
Fahrenheit Unit
PSI Unit
Fahrenheit Unit
PSI Unit
Fahrenheit Unit
PSI Unit
[ATI E-Pod
Yeah i also come to know about the benefits of this wonderful gauge.
Thanks from my side also.
seo optimization
09-04-2015 12:30 PM
09-02-2015 01:10 PM
09-02-2015 01:08 PM
