:: ECS Tuning :: MINI JCW GP 2 Belly Pan Kit !!
Old 05-24-2013 | 01:53 PM
It's finally here, the MINI JCW GP 2 Belly Pan and we created a kit for you to fit it !!
The road is filled with hazards, lying in wait, ready to pounce, bounce, and bash your car. Rocks. Cans. Bottles. And some mystery thingy that just dropped off the dump truck ahead of you.
Protect your MINI and improve its aerodynamics with the GP2 belly pan. Made of a plastic composite with embedded fiber strands for added strength, this pan is a direct-fit installation that comes complete with clips and hardware.
Tough enough to protect your engine, tight enough to keep it cleaner. Go for it.
Belly, Belly Good
Fits:
R55 MINI Cooper Clubman /S/JCW (2008+)
R56 MINI Cooper /S/JCW (2007+)
R57 MINI Cooper Convertible /S/JCW (2009+)
R58 Coupe /S/JCW (2011+)
R59 Roadster /S/JCW ( 2012+)
Fits Manual Transmission and Automatic Transmissions*
*MINIs with Automatics Transmissions , rear driver side vent lightly touches bottom of transmission oil pan when installed. Minor trimming of the pan might be needed for rubbing.
Click HERE to order or for more information.
Old 07-23-2013 | 06:08 PM
robyb's Avatar
robyb
is there an access to drain the oil pan or does it require complete removal?
Old 07-23-2013 | 06:59 PM
speedkills66's Avatar
speedkills66
If there is access I'm ordering...If not, maybe.
Old 07-23-2013 | 07:23 PM
MikewithaMini's Avatar
MikewithaMini
Nice, quality piece. It really completes the under panels and diffuser. Easy on, easy off, but I don't remember if there is oil pan access, but I believe there is. Haven't been there since install a couple months ago.
Old 07-24-2013 | 05:04 AM
There is no engine oil access little panel on this belly pan. Its one complete unit and made very well. Removal of the pan with the speed screws is easy. One trick is to place you hand in the center to hold the pan while the other hand uses a philips head screw driver to then twist the speed screws which unscrew with about a quarter twist. They are made to come out easy as they don't have long threads. And snug tight when you install. There is little plastic washers we included in the kit, which the additional hardware, that holds the speed screw in place on the pan ; so they don't drop to the ground. Then change the oil. I repeat in reverse for install.
Speed screws.
Old 07-24-2013 | 06:01 AM
yetti96's Avatar
yetti96
Oh la la. Undercarriage sexiness.
Old 07-24-2013 | 09:31 AM
Charlie Victor's Avatar
Charlie Victor
When will this be available again?
Old 07-24-2013 | 10:08 AM
Charlie - Sorry, but we don't currently have a eta. But once they do come available again we will let you guys know asap.
Old 08-16-2013 | 03:33 PM
eRock's Avatar
eRock
Did you guys raise the price on this?
Old 10-14-2013 | 01:35 PM
There was an increase by MINI on the part. We have all the hardware you need to install it.
We have them in stock
Old 10-15-2013 | 06:21 AM
ATCQL's Avatar
ATCQL
The price was raised TO 259.00.i spoke to someone from ECS yesterday. Q
Old 11-12-2013 | 05:33 AM
Old 09-02-2015 | 08:14 PM
13WSCRJCW's Avatar
13WSCRJCW
Is this GP2 Undertray Kit a Genuine MINI part ? Do you have a list of the fasteners that are required to install and their individual prices ?
Old 09-03-2015 | 04:52 AM
Yes, Genuine MINI, we created the install kit with factory hardware, first in the world to do that. All the hardware comes with it to install as a retrofit kit.
What model do you have ?
Old 09-03-2015 | 06:14 AM
13WSCRJCW's Avatar
13WSCRJCW
I have a 2013 JCW with the LCI Aero kit. Can I purchase the hardware by itself ? Only reason I ask is I purchased the Belly pan from my local dealer.
Old 09-03-2015 | 06:15 AM
PM me and I can help you out.
08-07-2015 09:51 AM
08-07-2015 08:10 AM
08-07-2015 08:02 AM
08-05-2015 02:11 PM
08-05-2015 02:10 PM
Quick Reply: :: ECS Tuning :: MINI JCW GP 2 Belly Pan Kit !!
