New Union Jack Tail lights! R56-R58 MINI Coopers!
#26
No problem.
#27
Friends, install this product, but when we start the vehicle with the stops off, the headlight or right stop blinks, meaning it turns on and off for several seconds and then stops doing it, otherwise it turns on well when you turn on the lights, stop or put lights of parking. this is normal? thanks!!!
#28
Do you have a video, my guess is that its the bulb check in the LKM that is normal. When you put in leds in a non led set up that can do that on start up for the first time. Then it stops.
#30
Yep, you are getting the bulb check. All LEDs do that when you switch from non LED bulbs on Gen 2 MINIs. Just on start up for the first time. They system is checking for bulb outs.
#31
yes, after a few seconds it stops flashing and normalizes, is this bad? Will you have any problem or damage the new stop or tail light? Thanks!!
#32
Nope, mine does it on my R58 on the front marker leds i swapped out. Its normal.
#34
#35
#36
Welcome
#37
No aftermarket ones yet but did you see these: Post #41 its the new oem blackline ones and you will need a harness
https://www.northamericanmotoring.co...-lights-2.html
#38
We have an updated brand and vendor for these Union jack Tail lights with more options
We did not forget about our Gen 1 MINI owner either.
https://www.northamericanmotoring.co...ml#post4654050
#39
We have F54 Clubman Union Jacks now!
https://www.ecstuning.com/b-ziza-par...1-f5417-sm-a~/
https://www.ecstuning.com/b-ziza-par...1-f5417-rd-a~/
F60 Union Jack here:
https://www.ecstuning.com/b-ziza-par...18492479r~ziz/
https://www.ecstuning.com/b-ziza-par...218492479~ziz/
Interior/Exterior Replace tail lights to Union Jack
Michael Bencosme
04-02-2021 04:38 PM
