It is simply a friction lock thing right, no screwing on or any of that jazz? And also, what is the diameter of the hole?
Not sure if you were asking about the stock **** or the Whalen, but the Whalen **** is not a friction fit - there's a spring-loaded collar that you have to retract as you push the **** onto the shifter shaft. Once the **** is fully seated on the shaft, the collar locks in place. After that, there's no way to remove the **** without first retracting the collar, no matter how hard you pull.
Sorry, I thought that's what he meant by 'friction lock'.
Originally Posted by Jeremy1026
Is the stock shifter the same diameter as the CVT 'shifter'? Muwhahaha (I think I rigged it to work)
