Interior/Exterior Alta Light Bar Legalities
They can only be fogs down low and be no less than 12". When I did fogs, there was a MD inspector there and said if the car was inspected it would fail ... less than 12". (assumming the bottom of the lamp).
Probably not what you wanted to hear but that is the law.
And ... as it says, you must wire the fogs to go out with the high beams on and ... there is another law that you can only have four (4) lamps on at any one time, in other words, if your parents are following the law, you can runs the two fogs and two lows or the two driving lamps and two highs but NOT six lamps at once.
This presumes you dont have fogs already because if you do, you cant legally run six sets of lamps ... you can bolt them on but not use them all at the same time
How are you getting around the license law? Your parents dont care?
I would find somewhere to mount the front plate, it looks like a tow hook mount could potentially work for running the front plate. This sucks though, I'll probably have to do a 2 light thing, either PIAA or OEM
Why? If that is a pic of your car, it looks like you already got fog lights. There is nothing that says you can't have additional fogs, you just can't have six lamps on at one time (legally). If you mean the plate ... I dunno.
"Any motor vehicle may be equipped with not to exceed two fog lamps"
That is pretty simple. If you got two fogs, then that is it. You cannot legally add two more.
It does not say but to be safe, I would presume it means the bottom of the lamp for the minimum distance and the top of the lamp for the maximum distance. But I have never heard of any copy getting a ruler out and actually measuring them. Its when you sell the car or get it inspected they will measure and then you can't get it inspected.
Jeremy1026: Thank you for your interest in our product. You are correct that the laws vary from state to state on license plate and lamp location, amount illuminated at any time etc. Most states will allow you to mount as many as you want, but only x amount can be illuminated in any situation. Meaning 2 + high beams, or 2+ low beams, not to oncoming traffic etc. But you should be able to mount as many as possible for the look that you want. If you do choose to only do two many clients remove the center two and mount the plate in their vacancy.
I am happy to help with any questions or concerns! Let me know how I can help further. Enjoy the drive!
Since he already has two fogs, no more fogs. It does not say anything about driving lamps. When I had my fogs mounted, there was a state inspector there and he specifically said that the car would not pass inspection (when selling).
although i am in virginia this is want my inspection place said, only 4 lights on at a time so even two extra lights, oem or not, are illegal, cuz the mini high beams run in conjunction with the lows, they said i needed covers, the other method i came up with was un-clip the wire under the bonnet so the lights don't work and are on the car for decorative purposes, get car inspected...then...i dunno you will think of something
get it?
get it?
Talking to your local cops is probably a good idea, though they don't always understand the laws they are supposed to be enforcing.
I live in a small town in Maine. One day one of the cops pulled me over for having my factory foglights on. She didn't give me a ticket, but I kinda wish she had. When I got to work I checked the state law, and found that she was completely out of line. I now carry a copy of the statute covering foglights in my glove box, just in case she decides to stop me again.
If you ask a question, be SURE you want to hear the answer.
See http://www.berwynheightspd.com/tinted%20windows.htm
Its a great link, local PD, about tint and lighting laws. In particular, read this quote:
22-230(c) USING LAMPS OR EQUIPMENT - A person may not use on a motor vehicle, trailer, etc., a Headlamp, Auxiliary or Fog Lamp, Rear Lamp, Signal Lamp, or Reflector which reflector or lamp is required under this title, or parts of any of the foregoing, which tend to Change the Original Design or Performance.
Although this doesn't apply to you, this does apply to all the people who try to change to Xenon lights in Halogen reflectors ... very IMO lame.
I got mine because I live on the edge of a heavily forested area with a large deer population. The police in my area tend to be fairly strict, but as long as I treat the driving lights like high beams, I can't imagine that I'd ever have any trouble with it. When I had a Wrangler, I had 7 auxillary lights. In Missouri (and probably any state) its illegal to use them on the road. However, in the right conditions and using some discression, I would think you would be okay anywhere. Officially, Missouri allows one set of auxillary lighting. So it'd be okay to have only 2 on.
07-16-2020 12:54 PM
