Interior/Exterior TSX xenon projector retrofit
I just bought a xenon kit, but the result is not as good compare to xenons with projector. To resolve this issue, I just bought two set of TSX projectors (S2000 are the best, but TSX is cheap and the result is still fairly better many others). I was thinking running 4 low beams and replace the highbeam since I will never use them.
Here is my concern, I after looking through several post in NAM, people had trouble disassemble the headlights because there are three bolts holding the unit together. Is there a solution for this? Also, what is the best technique to take the headlight apart: oven, heat gun, or dremel? For the folks that done similar project please help me. Thank you
BTW, the xenon kit is out and Vision Plus is back on.
09-29-2015 12:17 PM
09-29-2015 12:16 PM
09-29-2015 12:11 PM
