Interior/Exterior DIY: Checkered Driving Lamp Covers
Old 06-09-2007, 01:20 PM
aznqtboy984's Avatar
aznqtboy984
aznqtboy984 is offline
Some of you have been asking about how I created my checkered driving lamp covers, so I've decided to document my process and post this Do-It-Yourself Guide. The whole process took about 2 hours, including drying time. I had decided to do this because the driving lamp covers that come with the R56 driving lamps are plain white (not black like the older ones). The white doesn't match anything on my MINI, so making them checkered matches my checkered sunroof.
Here is a picture of the result:
Items you will need:
-white MINI driving lamp covers
-masking tape (at least 1" wide)
-pencil
-ruler
-box cutter, scissors
-Krylon Fusion paint for plastics in a shade of black (I used Black Semi-Gloss)
-plastic wrap and black permanent marker (optional)
STEP 1
Begin with a clean driving lamp cover.
This part is optional:
Wrap the front with plastic wrap.
Smooth out the front and tape to the back with masking tape.
With a black permanent marker, draw a 1"x1" grid and fill in alternating squares. Just to see what it would look like, I traced around the word MINI.
In doing this, you can unwrap the plastic wrap and get an approximate idea of what shapes you need to recreate with masking tape later.
STEP 2
Line up pieces of masking tape edge-to-edge on something like a glossy magazine cover that you will be able to easily peel off later. I used a car brochure (thick and glossy). Measure out 1" squares and cut up. Make sure you have a sharp blade!
STEP 3
Peel off a masking tape square carefully and place in between the M and the N in MINI and center it on the I. Press the tape into the grooves and the edges of the letters. IMPORTANT: Make sure all edges adhere securely to the cover. This will ensure even and clean squares later on.
STEP 4
Place another 1" tape square directly next to the first square. This is a placeholder square and will not need to be secure. Now place another square next to that. The second square can now be removed.
Repeat STEP 4 on all four sides of the first square until your cover looks like this:
STEP 5
The square in the corners are next. The tops and bottoms of these squares will have to aligned optically with the squares they are next to. This means that they will not necessarily look straight from the side, but they will look aligned when you look at the grid straight on. Secure only 2 edges for these side squares, and leave the rest hanging off.
STEP 6
If you refer to the plastic wrap from the beginning, you will notice that this next step will require you to make "trapezoids" for the remaining side squares. The plastic wrap will give you a general shape of the pieces. Again, these have to be optically aligned so that when looking at the cover straight on, the squares will appear to follow the grid. This part may take alot of trial and error, and is one that I personally found the most difficult. You will use the remaining tape squares to form these "trapezoids." Remember, the tape can be overlapping and even multi-layered and bulky, as long as the edges are clearly defined.
View from the side:
Press down on all edges, and you get this:
STEP 7
After making sure ALL the edges are secure for each square, lay the driving lamp cover down on a flat, covered surface, and spray on the Krylon Fusion. Use broad overlapping strokes, making 3-4 passes for even coverage, and make sure to get the sides too.
STEP 8
Wait a half an hour. During this time, you can prep the other driving lamp cover. When the cover is dry to the touch, you can start slowly peeling the masking tape squares.
Last square!
Ta-da!
And from the side:
If some of the edges are not clean enough, you can use a blade to "trim" off the excess by scraping at the paint.
Have fun!
Old 06-09-2007, 01:37 PM
#20Works4me's Avatar
#20Works4me
#20Works4me is offline
Nice job looks great!
Old 06-09-2007, 01:39 PM
ChrisMCS04's Avatar
ChrisMCS04
ChrisMCS04 is offline
Peace Keeper
Very Nice!
Old 06-09-2007, 02:19 PM
TwistySister's Avatar
TwistySister
TwistySister is offline
Those look really great. They really help to bring the car all together. I also love the chrome mirror covers! Maybe the new checkered handles would be a nice touch too. Of course, I am a bit over the top with the checkered thing. A nice clean and professional looking job on the covers with an excellent explaination of how to!
I wanted checkered covers for my Hella driving lights. I have a roll of checkered vinyl (contact paper). The white plastic covers say Hella in the center and have an oval near the outer edge. I made a tracing of the oval. Then I centered the tracing on the vinyl and carefully cut them out. It was a bit tricky getting them to lay flat as the covers are slightly convex. With a little work I got them on smoothly. I can faintly read Hella through the checkers. At first I hated that. Now I realize that one can still see that they are Hella lights and that's not all bad. At some point I'm sure I'll have to upgrade to a better quality vinyl from one of the great vendors here on NAM. I've also used my vinyl to make covers for the caution stickers on the sun visors. I have some MINI wings stickers that are just the right size so I added them too. I made a steering wheel center cover by making a tracing of the center and the MINI wings. I cut out the circle and the wings. It was a challenge, but, I got that on smoothly too with the original wings showing through in the center. Today I ordered a new Whalen Shift Machine **** with the Aesthetic Creations checked wing center. It's going to look so great! :impatient
Attached Thumbnails DIY: Checkered Driving Lamp Covers-img_0521.jpg
Old 06-09-2007, 03:20 PM
chows4us's Avatar
chows4us
chows4us is offline
VERY NICE JOB!
I love checkers!
You could have been lazy like me and just bought them (maybe not out yet for R56)
Old 06-09-2007, 08:15 PM
aznqtboy984
yes... I would have, but it's currently not available for the R56.
Old 06-10-2007, 06:32 AM
ltjpunk7's Avatar
ltjpunk7
ltjpunk7 is offline
and that's the nicest damn outfit i've ever seen a painter wear!
Old 06-10-2007, 08:13 AM
Silverbullit's Avatar
Silverbullit
Silverbullit is offline
You did one heck of job on those covers!! I bought checkered covers for my 04 MC back in 04 and paid $85.00. I wish I would have had your post back than. Nice job!!!
06MCS/DS/B/Bbonnetstripes/Whalen8ballshiftmachine
Old 06-19-2007, 03:23 AM
mini matt's Avatar
mini matt
mini matt is offline
On an unrelated note, when you installed your checkered sunroof decal did you notice a big difference in how much light your sunroof allowed in. I'm trying to decide whether to install the same decal or just tint the glass so your input would be helpful. Thanks.
Old 06-20-2007, 11:06 AM
aznqtboy984
I originally wanted to tint my sunroof. After reading some threads here on NAM, I decided not to. For the checkered sunroof, only the white part is vinyl. This blocks some sunlight into the car.
Old 06-22-2007, 05:11 AM
mini matt's Avatar
mini matt
Are you refering to the "exploding" sunroofs ? If so in those cases was it the "darkness" of the tint that caused the problem ie: the darker the tint the higher the risk or is it any tint ? I'm considering going with a 20% tint because my tinter said although he's also heard of it happening he's never had it happen to any he's done personally and figures if it were to it would be more likely the "limo"= 5% because the really dark tint attracts more heat. What have you heard ?
Old 06-24-2007, 12:21 AM
Alpha Motoring's Avatar
Alpha Motoring
Alpha Motoring is offline
Nice job!
Old 06-24-2007, 09:47 AM
rattmobbins's Avatar
rattmobbins
rattmobbins is offline
Whoa whoa whoa! Exploding sunroofs? Can you please provide me with a link to a thread?
Old 06-24-2007, 09:52 AM
gokartride's Avatar
gokartride
gokartride is offline
Very nicely done!!!
Old 03-31-2008, 04:40 PM
ChubbyChecker's Avatar
ChubbyChecker
ChubbyChecker is offline
Finally got it done
Thanks, aznqtboy984. I've been saving this thread since June because I knew sooner or later I was going to install OEM lights. Finally got them done this weekend and following your DIY they came out great. I did them basically the same way you did, except I masked off the MINI and painted the letters silver. I think it came out pretty sharp. Thanks for the awesome tutorial.
Old 03-31-2008, 06:33 PM
Minidrivr's Avatar
Minidrivr
Minidrivr is offline
Those look great! I hope they hold up. I painted my white ones all black, 4-5 light coats of Krylon's plastic paint. But in less than 1000 miles they were full of chips down to the white. The car didn't have any rock chips in that time however.
I opted to just buy the black OEM ones. The checkers look great though!
aznqtboy984, how has the paint held up?
Old 03-31-2008, 08:29 PM
xnotfunkylex's Avatar
xnotfunkylex
xnotfunkylex is offline
Great idea. Did you spray a clear coat over it? Seems like they would be pretty prone to chips up there.
Old 03-31-2008, 09:03 PM
Minidrivr's Avatar
Minidrivr
I didn't clear mine. I don't see why a clear coat would stop chips. Clear is just another layer of paint. But maybe it reduces them getting all the way through.
Old 04-01-2008, 05:16 AM
edijak's Avatar
edijak
edijak is offline
Both of these mods are very nice. Thanks for your efforts
Old 10-08-2008, 08:25 PM
minicooperguypeter's Avatar
minicooperguypeter
minicooperguypeter is offline
so how do you mask off the MINI and paint it silver? that looks really cool cause i'd like to still see the MINI on the cover.
Old 10-08-2008, 08:39 PM
ChubbyChecker
After the paint dryed on the checkers, I used masking tape and an Exacto knife to mask off the letters. I used some "chrome" model spray paint on the letters.
Old 10-08-2008, 08:46 PM
minicooperguypeter
give me some slack that i couldn't figure that out. it's late and after a long day....
thanks
Old 02-23-2009, 08:54 PM
ChubbyChecker
I got to thinking about the silver MINI letters on my covers and thought how nice they'd look if they were actually chrome.
I had a friend make a chrome sticker for the back of my wife's cabrio and asked him if he could spare a 1-1/2" strip about 12" long.
So, with a little patience this is how they turned out.
Attached Thumbnails DIY: Checkered Driving Lamp Covers-img_0273.jpg   DIY: Checkered Driving Lamp Covers-img_0274.jpg
Old 02-25-2009, 03:19 PM
kreative's Avatar
kreative
kreative is offline
i dig the checkers!
Old 10-24-2010, 09:50 AM
J Dubya's Avatar
J Dubya
J Dubya is offline
Looking for white light covers
I was linked to your thread by someone in my PSMINI group. I am actually looking for white covers for my lights, but cannot seem to find them anywhere. Any suggestions? I can find black, chrome, checkered and union jack, but no white.
Quick Reply: Interior/Exterior DIY: Checkered Driving Lamp Covers
