Interior/Exterior How To: Swap Side Markers
In my ongoing quest to de-bling the Mach V MINI, I swapped to Cooper (non-S) side markers. Here's how to do it...
You'll need a good-sized flat-head screwdriver. Not a teeny one. A flashlight helps to see what you're doing.
1. Open the hood.
2. Look inside the fender to see the locking tab on the side marker assembly. It's on the forward side. The locking tab prevents the assembly from sliding forward.
3. Depress the locking tab with the screwdriver. I levered a little against the hood hinge. Be careful! You don't want to bend any bodywork.
4. While still depressing the locking tab, slide the side marker assembly forward. It'll pop free.
5. Undo the wiring or bulb socket from the side marker assembly.
6. (Optional) Replace the amber bulb with the bulb of your choice. We used a clear conventional bulb. Be aware of your local laws!
7. Attach the wiring to the new assembly.
8. Push the assembly into place by pressing in and sliding it back. It'll lock in place.
9. Done!
Before:
After:
--Dan
Mach V
FastMINI.net
1. Open the hood.
9. Done!
Before:
After:
--Dan
Mach V
FastMINI.net
M6
on
de-bling - Nice usage.
clip clip clip
After:
--Dan
Mach V
FastMINI.net
clip clip clip
After:
--Dan
Mach V
FastMINI.net
Every time I see your MINI, it is looking better and better. +1 I do like those wheels, still an option for my 2nd set.
Thanks!
In stock, whenever you're ready!
--Dan
Mach V
FastMINI.net
--Dan
Mach V
FastMINI.net
Hmm. Photoshop, anyone?
Some day when I have some extra funds laying around, I'll be doing all the fender trim body color. Perhaps that piece will turn color at the same time.
--Dan
Mach V
FastMINI.net
--Dan
Mach V
FastMINI.net
07-16-2020 12:54 PM
