Interior/Exterior Hood Air Extractor Scoop
08-03-2007, 01:06 PM
on
08-04-2007, 05:02 AM
Nice post trackertracker
08-06-2007, 05:21 PM
on
Should be about about 3 weeks to lift off
08-07-2007, 07:36 AM
on
looks great, but cuting the hood it going to be nerve racking
08-07-2007, 08:16 AM
Quote:
Originally Posted by
MiniStupidfun
It's the right of passage...
08-09-2007, 04:00 PM
08-10-2007, 01:33 PM
on
Maybe 2.578 weeks to lift off( can you tell that I want one
08-10-2007, 01:42 PM
on
How does it keep water out of important stuff under the hood?
jason
08-10-2007, 01:49 PM
on
08-10-2007, 02:27 PM
My little dose of LITHIUM
1QukMINI
jason
Which parts are "important stuff" under the bonnet that can't take a little rain, or wash, water?
Thanks,
08-11-2007, 10:15 AM
MSFITOY
LOL
Does anyone have pictures of the underside of the hood with the vent installed?
08-11-2007, 02:07 PM
on
1QukMINI, it comes with a little tiny mini man under the hood with a Major Mini Maxi Mop to keep
da motor nice and dry
08-11-2007, 06:16 PM
on
MSFITOY
Here's a different view...
PhysicsGeek
more fuel to the fire, where is my sawzall?:
...and I thought those were "just" vents. They look even better when you lift the hood!
08-16-2007, 12:52 PM
on
About 1.935486 weeks to lift off
Houston "we have a new scoop in our bonnet"
08-16-2007, 02:20 PM
on
with the set up above, I would be worried about having a puddling effect with all the crazy rain we have here in SC. maybe a drain system could be in order.
08-16-2007, 02:29 PM
on
why not just louver the whole hood and be done with it? Sorry, but I won't be sawzalling my hood anytime soon.Different strokes.This must be another one of those hot southern California things like the 180 deg. thermostat.Doesn't fly up here in the Northeast snow belt.
08-16-2007, 02:40 PM
on
trackertracker
Tosses spanner into the works.....
So will this scoop also work with the rumored upcoming DFIC V2?
08-16-2007, 02:49 PM
on
At Road Atlanta last Sat it was 104 deg. we ran 25 minute sessions most of that was at WOT, I never felt a loss of power from the begining of a session to the end, I guess I'm not sure what you after by cutting a hole. in the hood doing this is way down on the list of things I'm thinking about.
Reason: sp
08-17-2007, 12:20 PM
on
We need a Doctor Obnxs opinion on this.
At a range of ambient temperatures 70 tp 100 degrees : a range of
vehicle speeds of 40 to 100 mph ; a range of engine RPM's of 3,000 to
6,000 ; sea level 30.0 barametric pressure/ 35% relative humidity,
no wind speed; -----at what ,if any ,of the intersection of these parameters
does the rate of cooling of the M-7 DFIC with the new exit air vent
exceed the rate of cooling without the new exit air vent
(p.s.----you don't get partial credit if you say " hit it with a big stick"
as proposed in the Alta PSRS thread
IS THERE THE DOCTOR IN THIS HOUSE
08-27-2007, 10:56 AM
on
0.835462 weeks to M-7 new scoop release
08-27-2007, 12:19 PM
on
so really, has anyone thought about puddling while driving? the wind would be pushing water through the cooler and then...................
08-27-2007, 12:24 PM
El_Griton
You can't see it in this pic...
...but I believe there are drains in the outlet duct.
08-27-2007, 03:25 PM
on
If there be no drain, then I will make a drain
08-28-2007, 11:39 AM
Sorry for reposting this, but I'd really like to see a pic.
08-28-2007, 02:34 PM
on
I haven't seen a pics of the hood underside either.
Okay M-7 please toss us some food
