Interior/Exterior How do you take off these tail lights?
1. open the rear side compartments
2. Find the correct wrench size, preferably open ended. I cant remember 8 or 10mm? or as it a 6mm?
3. Lefty lucy for 5 minutes. or 1 minute if you are using an open ended ratcheting wrench, if you are consider yourself lucky. the posts on these are long.
4. push through the back. the weather stripping on the lamp may make it a little hard to get out but you shouldn't damage anything.
that should be about it.
Oh yeah, some where in these directions you should disconnect the lights it would probably help. also disconnect the battery for extra safety.
Both are the easist pain in the @sses. I think the tails pissed me off the most. Socket wrenches are to shallow and standard wrenches were to slow.
yeah i ended up using a screw driver attachement socket thingymajig ( not a tool name expert ) but i def spent about 5 minutes each to get them off ...after that it was a breeze but the side vents mannn its just as bad as the mirror caps im so nervous to break the pieces off ...and side pillars.....i hate those too !@ lol
There isn't a whole lot of room to maneuver in those side pockets, that's why it takes so long. I'd say 5mins give or take depending on how fast you are with a open ended box wrench. That's why i said it would be faster and you would be lucky if you had had a ratcheting box open ended wrench.
the side grills were painted with duplicolor auto trim paint (flat black). If you do it, make sure to give the grills a good sanding or you'll end up doing it a few times over.
nope i was serious about 5 minutes each on the tails....its tricky getting your hand in there while holding a ratchet and turning the ratchet ....anywho i used duplicolor sandable primer on my side vents sprayed a few times over and so far so good ...but yes sand the peices first....you dont need much sanding as primer is meant to stick well ..but sanding will result in better results..i used a 320 grit for a light scuffing and the duplicolor black sandable primer actuallyyyyy comes out a perfect match for the anthracite downtubes and dash in my mini ...i lucked out i guess =)
golden child, your sides look great! did you tint the lens? is that a red bulb inside or just the relection from the S logo or something else nearby?
I now have tinted film that I used for my arch reflectors, so I wonder how well that would wrap around the lens? hmmmm???
Thanks The lens can be bought at outmotoring.com. They are a little pricey for what they are but I looked around and they are pretty pricey everywhere. So, since they are a MINI shop I figured I give them my money. The red is probably a littl bit of reflection fron the "S" and the orange bulb in the lens.
you need a heat gun to wrap the contours of the sidemarkers....the tinting film generally is rather thick so you will have creases galore in the film unless you wrap it with a heat gun
07-16-2020 12:54 PM
cm.d
08-19-2015 08:51 AM
