Interior/Exterior Exterior Door Handle Covers
Ahh I don't care which ones actually. I am considering painting them instead of the actual handles to see if that is easier/better for blacking out the chrome.
I did not want to get into removing and replacing the handles so I opted for the covers.
Waiting, waiting, waiting....
good to hear theyre covers. I dont want to remove my handles either. I found a set of chrome covers on eBay for about 70 bucks. may go that option..just paint them black to match the car and stick them on.
The AC door handle covers are DEFINITELY the way to go! I'm not sure what material they are made out of but they are definitely VERY high quality. You really couldn't ask for anything more - great quality, great looks, and great ease of installation (just peel and stick!).
I think the ones that you can order that are complete replacements - the checkered, union jack, or black jack ones are shrink wrapped to give them that appearance.
Celia
Celia
I covered mine with them still on the car with 3M flat black vinyl.. Not the easiest job but can be done. Did have to seam it on the bottom side of handle. ( can't see it unless you are looking from ground up ) Also in an area close to the key hole. Plan to redo that one soon to try to get it with out the seem.
Celia
on
It's not really that big of a pain...the first handle is a learning experience, just like anything. The second handle flys buy. You need to have a T-handle 5mm ball joint allen wrench and a ratchet offset screwdriver with allen/torx bits. The ratchet is for the end of the handle towards the front wheel and the ball joint allen is for the end towards the back...you have to pull/peal the rubber surround up to get to this nut/bolt. The only real hard part is getting the wire back in the plastic guide. If you have a couple ounces of patience, it doesn't hurt either. It's one of those jobs where you can't see quite what you're doing, so just close your eyes and get 'er done
Celia
Celia
do cover
Celia
Celia
07-16-2020 12:54 PM
Interior/Exterior Need Help With Exterior Decisions (05' MCS PHM/W)
boostedhaze
01-02-2018 07:26 PM
xpunisherx
09-01-2015 11:47 AM
minimaximum
R55 :: Clubman Talk (2008+)
08-14-2015 04:05 PM
