Interior/Exterior Help I need this part...
Good Day NAM!
Where can I purchase another one of these? What would it be called?
If you cant tell from the crappy pic im talking about when you pull off the shift **** on a mini and you have that shaft piece that looks like black plastic.... How it it connected? screwed on glued, welded?
Which part? The shaft or the ****?
Good Day NAM!
Go to.. http://www.realoem.com and put your car info in. You'll need the Build-Date on your door jam for a more accurate depiction and then look for the part you need there. After that you can either go to http://www.pelicanparts.com or to your nearest Dealership for the part you need.
Nothings broken. Just wanted to buy another one of the stock MCS stick shafts. Have a project in mind....
Hmm, it looks like you can't buy just the stock shifter shaft, you have to buy the mounting cage that goes with it too:
http://www.realoem.com/bmw/showparts...86&hg=25&fg=05
Look for Condition A; that's the old style [up to 1/2004 build]. The part number is 25117518850
Interior/Exterior To those installing a GP rear diffuser with an aftermarket exhaust
Brandonpt
09-09-2013 07:48 AM
