Interior/Exterior Check my car I just got it back
#29
ok the problem is i parked the car in my driveway and the battery died but i have no gas so im kinda in a perdicamint, oh and i have no insurance so i dont want to risk hurtin my beautifull black car, i have anohter car for now but i know im just as bummed as you guys but i will have them by sunday
#35
The process in theory is very easy, it's the practice thats a bugger. Not to take anything away from grddyperp it seems we both are doing some similar mods here since I've also molded in the scoop in the bonnet I'm in the process of modding.
In a nutshell:
Remove scoop
Grind to bare metal the area of the bonnet where the scoop sits and some of the surrounding area.
Grind finish off scoop
Test fit
With scoop in place fill gaps surrounding area with a panel bond material. Let cure
Sand smooth
Fill any gaps or low spots with appropriate filler
Sand
Fill any gaps or low spots with finer grade appropriate filler
Sand
Scuff entire bonnet
Primer coat
Sand
Primer coat of another color to use as visual aid
Sand
Spot prime any bare metal
light sand
Paint
A lot more to it then that, but those are the basic steps.
Paint is easy, preparing to paint so it comes out right is a lot of work
The thread I have on venting my bonnet has pictures of some of the process
In a nutshell:
Remove scoop
Test fit
Sand smooth
Sand
Sand
Scuff entire bonnet
Primer coat
Sand
Sand
light sand
Paint
#37
so now my battery is completely dead and i have to try and find a way to get into the car at the moment it has gas and now i just need to find the emergency switch to get it and then charge the battery so i will have more pics soon i have some of it in the driveway i will try and get them up tomorrow. sorry for the delay, will keep you posted.
p.s. The process that gnatster said more or less
#38
#39
so i finally got pictures but i cant post them so heres a photobucket link hope it works for yall http://s256.photobucket.com/albums/h...t=1127d95e.pbw
#42
#43
nismo4life
08-05-2015 08:31 AM
