Interior/Exterior My new homegrown lightbar!
A few weeks ago, I fabbed a light bar for the front of my S, because I felt that I just needed to see better at night.
So I took the existing mounts that I had already made a year ago (from this thread https://www.northamericanmotoring.co...ustom+brackets) and used those as mounting points for the new bar. The bar is some 3/4" (I think, I can't remember) steel bar from home depot that was bent in a conduit bender to fit along the bumper, and has four tabs welded onto it. The outer two tabs are bolted onto the old mounts via the outer two lights (i.e., the lights are actually holding the bar on.). The bar is fairly stable and only shakes if I hit rough bumps. But on smooth roads, it's pretty decent. The bar is painted, but the inside is a bit rusty since it's just bare steel. I will have to find some caps to put in the ends of the bar so it can't be seen. I know, the wiring is sloppy, but that can be fixed easily when I have time.
Total cost for my entire light project seen below: approx $180 and a friend who can weld.
Check it out:
Check it out:
Hella 500's. But as you can see the inner ones are slightly different.
I wasn't going for stealthiness, I was really going for pure function here.
Looks good by the way.
The inner two lights are farther forward, so that's why. But like I've said in another thread, the "new" hella 500's are slightly different than the old, so many they changed the size slightly.
Interior/Exterior WTB: Palo Uber Lightbar....HELP!!!
StJamesG8
05-21-2009 08:12 PM
TWISTER
Tar Heel MINI Motoring Club
08-26-2005 07:00 AM
