Interior/Exterior Replacing door handles
#27
#28
Home Depot sells a Husky allen kit - not t-handle, normal ones, but they come with a plastic adaptor so you can use the long side.
as for prep, hit them with an emery pad, tape up anything non-chrome, wipe with a cleaner to get oil and dust off, spray with a self-etching primer...a light tack coat, then 2 or so light coats. Let it dry....light tack coat with your paint, then 2-3 light coats. It helps to let everything cure for a few days before handling...the label says 'dry to the touch in 20 minutes' but they lie
#29
#30
#35
Wow, just finished the second door. From walking into the garage to turning off the lights was 31 minutes. After you've done this once, it's a piece of cake. Highly recommend however a socket torx30. Of the 30 minutes, over half was loosening or lightening the screw holding in the front end of the door handle. I have a torx30 bit, but it requires a socket adapter to go on my ratchet and there isn't room. I went to go buy one and the salesman suggest an Allen wrench instead, as they are less likely to break or strip. Wrong...get the socket, your knuckles will thank you.
#37
on
Thanks to all the great information from all of you and due to special New Years Eve help from OctaneGuy, ImagoX, Sin MINI and especially, glnr13, my checkered door handles are FINALLY installed! While the first door was a PITA (due to some problems documented in another thread), I did the second door in 35 minutes. As many advised, I used a mini socket and a T-handle, ball head hex set purchased at Sears. Here is the result:
And here are my new JCW checkered floor mats too:
#41
#42
on
When you say front bolt do you mean the one closest to the edge of the door? If so, you access that one by lifting the rubber flap at the end of the door and passing the hex wrench the hole under the flap. The other one is best accessed with a mini socket wrench and hex bit.
#43
07-16-2020 12:54 PM
Interior/Exterior Need Help With Exterior Decisions (05' MCS PHM/W)
boostedhaze
01-02-2018 07:26 PM
xpunisherx
09-01-2015 11:47 AM
minimaximum
R55 :: Clubman Talk (2008+)
08-14-2015 04:05 PM
