I'm not worried so much about the cost for a resonator or header, I'm more concern about smog check. If I buy either one, will my car still pass smog check?
Anyway you could always set the center resonator up with a quick release fitting. Keep a straight pipe in there all year until it's time for smog check & swap in the resonator.
A resonatorectomy will not effect emmisions as it is "cat back". It does add more sound and lots more pop,pop,pop when you lift. good for the butt dyno
