Interior/Exterior 4 rally lights
Does anyone know how a four lamp system will effect how much air gets into the bonnet scoop on an MCS? I've been thinking of eventually going to a 4 light system, but all the sudden the thought about aerodynamics popped into my head, and now i'm not quite sure if it's a good idea on a MCS...
Rocketboy_X
Rocketboy_X
My biggest issue is the way my badge bar moves.
The way they are bolted through the grill, and the weight of the lights, they bounce. haha. But, the airflow's no problem (I have a pipercross).
The rear fog Light is NEXT... haha.
Happy motoring, and show us Some pictures of your lights!
Danny
Danny
I found out something recently about the relay included in the stock kit. If you happen to be running 4 driving lights through this relay it gets REALLY hot and you end up cooking it. The replacement is 100 fat bills from BMw/Mini and I haven't found an identical replacement aftermarket yet. I did find one at a local electrcians shop and may revamp the works to use it instead. Its rated much higher and should solve the problem.
What happens is they beginto strobe on and off while cruising down the road and then the relay fuses together. Can't turn the damn things off unless you shut off the lights. Bad thing to do at night.
Note: they had been on about 1.5 hrs when it started.
on
07-16-2020 12:54 PM
12-23-2015 10:36 AM
ryGuyMCS
10-20-2015 02:24 PM
JHolland
08-13-2015 10:47 PM
