Interior/Exterior Any DIY's for black-out door handles, light rings, gas caps?
#227
#229
#231
#232
I tried taking out the bolts today. I have a small range of tools, couldn't get it out. I've heard someone use small pliers on them?
#233
Having the right tools is the key. That's why it was soo easy for you. I didnt have that little ratchet thing and was forced to use a needle nose vice grip with the bit attached to it. Took a very very long time. Glad to know that the information here on NAM was able to help others and make it a little easier for the next guy. Ya gotta love this place
#234
Yes having the right tools is a must. I have a set of ratchet wrenches and an Allen tool that fits in the 10mm so that made it very fast.
I started color matching the chrome in the tail lights today and had to Dremmel the lense off. I only got one doen before I had to head off to work byt it looks so much better in dark silver .
Kinda makes me want to color match my grill, handles, and gas cap!
Ill get some shots up when I finish the other tail.
#236
#239
Oh yeah, I actually did that when someone mention tools falling in and not coming back out.
Those pics are really good. The only problem is the two nuts on top (last picture) are really hard to get to.. my socket bit isn't deep enough and I'm afraid to strip them using pliers. It's also in the most awkward position. Hmm...
#242
#243
Got the sidemarkers out today. Everyday I try to get another piece out. What I'm stuck with right now is the right tools for the bonnet scoop.
I still can't find the right nuts to take off for the head light rings... I only found one. Am I suppose to take the whole entire headlight off to take off the rings? Is it possible for me to mask off the car and just spray the rings on the car?
#244
on
Bonnet scoop is easy to do...I'm not sure what is giving you problems. I'm able to see all 4 and loosen them with my hands (after loosening them with a socket).
Headlight rings...I would suggest removing the headlights. you could mask them off and paint them, but I'd be afraid of the edges not adhering right. I just shot my door handles, and I'm having this issue. On the backside (where your fingers push the tab to open the door) I didn't shoot down in there far enough, and it's starting to peel up...Ugh...
Head lights are held in with 3 nuts, then if you have the headlight washers, you'll need to disconnect the fluid hose to the light. Then they just slide out toward the front of the car. It takes a little getting used to it, but on the second one, you'll have it out in 5 minutes
#245
Hey guys, don't know if you've seen the thread yet, but I figured I'd let you know that I'm compiling all this info into one DIY here
https://www.northamericanmotoring.co...d.php?t=156693
Well, not THIS info...but how to do all of the above
Of course for the plastidip users...I guess its even easier :D
#246
The bonnet scoop is hard for me because I don't have a deep enough socket.
BTW for anyone doing the S markers. I'm doing it as we speak and my best tip is to use a hair dryer to remove the S. Sticky fellas...
#247
on
Nope. All should be able to be seen by just looking at the back of the headlight. My wife has the car right now, so I can't go out and do an exact locate for you. As soon as she gets here, I'll verify for ya.
Just for your FYI, headlights and rings are all one piece until you pull out the whole housing. Then you'll want to use a small head flat blade screw driver to undo the clips and reomve the rings. After you have a couple off, you should be able to slide the rings off the lights. I was able to do it and not break any clips. Just take your time and you'll do great.
#248
