Interior/Exterior Any DIY's for black-out door handles, light rings, gas caps?
#451
you have ordered them from aesthetic creations? have you recieved them yet?? I ordered mine may this year and payed them at the same time , but I have not recieved them yet!!! it´s almost half a year..
#452
on
Way to bring up a sore subject.... Ordered them May 27th, still waiting... It's a running gag with one of my friends... Just about daily he asks "Dude, did you get your handles?". So I'm going to hurry up and wait some more.
#453
time to put up a warning flag for that sorry company then..
#455
#456
on
I got the same story... "I'm sending 17 units out now, you should be in the next batch." Call a month later "I'm sending another 1X units out now, you should be in the next batch". Asked for a refund, he got irritated, and basically said no refunds due to wait times, you should've read the FAQ section (buried on his page, and info like that should be on the order confirmation page, not a FAQ). He said that it takes a minimum of 6-8 weeks, which is very different than saying it takes 6-8 weeks.
I opened a complaint with paypal even though I'm past the 45 days. I emailed about the situation and I got a response saying the following:
PayPal reserves the right to reopen any claim for investigation within
180 days if multiple complaints are received about a single seller. We
will notify you if this is the case.
So, if anyone is in the same boat, you have options...
#457
Mike is a good honest guy who just has a problem delivering his products.
I had the same type of problem two years ago when the door handle covers came out. It took months to get them. Then one was cracked.
BUT, when I told Mike he replaced both no questions and was very good about it.
So you just have to decide if you are willing to wait for a good product at a good price. (Yes I know sometimes an unacceptable wait but that is just the way it is.)
#460
#461
on
ive had my clubman for 2 weeks and ive been itching to blackout all the chrome parts...does anyone have any upclose pics of their finished jobs w/ the plasti-dip?...this stuff sounds amazing...also, does anyone know if the black engine paint work well on the tailpipes?
#463
Weekend Project
I plastic koted the front headlamp bezels, gas cap and side markers using Plastic Kote.
I used 3M buffing pad, cleaned with laquer thinner and sprayed 3 coats on each. For those who haven't used any paint thinning materials, DO NOT USE ACETONE. This will melt the plastic and you will have a mess. Laquer thinner cleans without causing melting of the plastic surrounds.
The Platic Kote really works well and is a cheaper, much cheaper alternative than what is out there. The can price at Lowe's was under $6. The paint removes without damaging the intented painted area.
Will see how it weathers under driving conditions, but intial assessment proves awesome.
Happy motoring folks.
Texas Cooper
Texas Cooper
#464
removing those headlight trims is not fun. You'll have to 'break' the double-sided tape seal at 3 places between the trim and headlight lense. Carefully pry with a small flat headed screwdriver, between the trim and lense. Once you get one of the tape seals busted, the other two are a little easier. I managed to get the trim piece off with only breaking a few of the clips. You'll want some of that heavy duty double sided tape or adhesive when installing the trim rings back in place.
#466
on
Thanks it is a non JCW which looked so good with the body kit and has been added on to include the JCW CF hood scoop, mirror caps and now the CF Wing. This next week I will be adding a Hoskiss 25mm rear sway bar, TSW lowering springs, end links and a few other engine mods
#467
#469
#470
#471
I used Plasti Dip on my Mini last summer and ran through a very tough Maine winter. A couple of observations.
I was very surprised that the small front grill section and headlight rings still look awesome. No fading, no peeling and no pitting from sand and grit.
The side scuttles and gas cap are also in super condition.
The belt line I had to do again. It really became discolored by road dirt and grit. It also lifted in a few places. I peeled the old Plasti Dip off, really cleaned it up good with Windex, reapplied and it looks super again.
I was very skeptical that it would last as good as it did.
The one area I will not redo is the door handles. Plasti Dip can stand up to highly handled areas. I'm probably going to pick up a set of door handle covers from Way Motor Works.
07-16-2020 12:54 PM
Interior/Exterior Need Help With Exterior Decisions (05' MCS PHM/W)
boostedhaze
01-02-2018 07:26 PM
mrjolliff
10-09-2015 05:55 AM
xpunisherx
09-01-2015 11:47 AM
