Interior/Exterior Any DIY's for black-out door handles, light rings, gas caps?
#26
just read plastidip can function between -30 and 200F
lastly, according to the can there is yellow, red, clear, white, black, and blue colors available. http://www.plastidip.com/
#28
I'm planning on de-chroming my taillights soon, although I will be staying away from cutting them opened for sure.
The year is important due to the type of adhesive used, I have an 05 and I know that they can be warned up and opened, and in most cases the same adhesive can be used if it's warmed back up.
I don't want to cut them if it can be avoided...
Will post more when I get there...
Nice job though, Lookin' good..
Oh yeah, also..... They don't need to be painted since the Chrome is simply painted on, you can actually wipe the chrome off to black which is the color underneath....
#30
yes, you have to remove the door panel. and the allen bolts are very tough to get to access. there is a write up on it. i will post the link when i'm not in the office, unless someone beats me to it.
#31
on
#32
Well, I'm Plasti-dipping my door handles now - first tried the liquid brush-on but NO WAY - too streaky. Wiped that off then masked a lot and sprayed - much better. not glossy, sort of semi-gloss-ish/flatish. Bit of a pain removing masking since the plasti sticks to it, too - had to use xacto. Won't be dry for 4 hours. Left door with keyhole may be more trouble, masking hole. We'll see....
But overall a lot easier than replacing handles.
#33
#35
on
#36
#40
#41
after u let it dry, just pick at an area in order to gain something to get a hold of.(either with ur fingernail or something firm enough to cut, but not scratch your paint underneath. once you have a piece picked open just pull and it all peels off. The thicker the coats, the easier it comes off as it is thicker, and enables you to peel it all off in one piece.
or you can do like i do....my gf has a fascination with it, and begs me to let her peel of the plastidip whenever i mess up.
#42
Well I decided to give this stuff a try since the paint I used before (primer, then color, then clear) took a beating this summer in florida sun. Last night I did my door handles with the plastic dip and I'm liking the look/feel (though it felt weird at first when being used to smooth paint). Seems very durable, is really easy to remove, and i love how well it matches the black trim around the car.
Sometime this week I will be repainting all my trim pieces with this stuff. Oh and I have a few surprises that I shall post up when finished :D
I am contemplating doing this on my rims. A while back I painted my rims with high heat engine paint because I felt that it matched the black trim visually pretty well, but the problem turned out that this paint seems to have a purplish hue in certain sunlight conditions. It could be that the paint was never exposed to heat. I've used it on my exhaust tip, which was baked in the over, and then months later on muffler and that heated itself up, so it is a good trim matching black. The rims, not so much. I used it on the door handles too, but same problem; purplish.
Could plasti-dip be my answer? I sure hope so. I better not have to rebalance my wheels tho. I did the first time painting, but that is because I removed the front weights in favor of having them only weighted on the rear.
#43
After reading people's results using "Plasti-dip I thought I'd give it a try. I used it on the three remaining pieces to be blacked out on Boo. Lyle from Vinyl Stylings did my headlight rings, door handles,belt line and (although not blacked out) my rear taillights in Ruby red. All that remand was my side repeaters and my gas cap door. I must say that it was very easy to do ! I goofed a couple of times on the gas door and just peeled the Plasti-dip off and re sprayed. Worked very well. Time will tell if it will last but, right now I've got to say it look really good !
Here are a few shots of the completed job ! Tell me what you think !
#44
#45
I think your in for a heartache trying to use the Plasti-dip on your head light rings. I wouldn't think it would hold up to any kind of rock chip or road debris no matter how many coats you put on it. I'm hoping it will work on my gas lid and side repeaters only because they won't take a direct hit from anything but, if it doesn't work out, I'll just peel it off and start again with paint next time. As I said in my post, I went with vinyl on my head light rings from Lyle at Vinyl styles. I had the rings installed over a year ago ! Not a mark on them ! As far as me getting the texture smooth, it took a couple try's to get it right on the gas lid. I'm pretty sure I just didn't take my time the first time around but no big deal, I just peeled it off and tried again until I got it right !
#46
i just went with painting them again and threw a lot more clear on them. holding up well so far. but i HAVE seen tons of people platidip their rings and say it holds up very well.
#47
#48
#49
My rings have been done since april and there is not a single mark on them. my scoop is holding up just as good.
also, if you find your getting little pits or pockets in your plastidip you are probably laying it on too thick and/or not allowing it to dry totally. ive experienced the problem quite a few times. also, dont paint in high humidity that will screw with your results as well
#50
Thank you DrPhilGandini, Very kind words indeed ! I'm very proud of how Boo has turned out. I've been fortunate to have an understanding wife threw all the mods I've done to Boo........... well let's be honest, she's just been putting up with me for the last two years waiting for the end of "new mods" shaking her head all the way ! LOL ! Thanks again !
