Interior/Exterior Carbonized gone wild!
#27
Here is something I was working on Saturday, part one of 3 things going on at the same time . I call it I.C., tilt .
that should give me enouph space to duct the I.C. , insulate it from the engine bay heat , and suck the flow through louvres in the hood.. I know it's not the right place to post this, but its kind of connected:See OP
#28
It's your thread, so you can post anything you want.
Very cool(no pun) to see you mod your IC like that, I ran mine like that a while back...
https://www.northamericanmotoring.co...ad.php?t=72261
I'm now working on fitting an R56 core in the lower grille area.
#29
Laurent, should given me a call .
I modified a Forge IC similar to what your working on. The pic is deceptive but I can get my most of my hand under the IC from the back.
The front of the IC was lowered - perhaps visible here
This was a forge prototype I worked on w/ Minspeed - as you can see I also built a fixed scoop to smooth out the inbound air and eliminate the "seal" against the hood. The scoop in theory pressurizes the air smoother than the seal against the hood. While the scoop is aluminum - on one hand it heat soaks on the other it helps pull the heat soak and increases air to surface area dumping heat sooner.
all theory.
Perhaps a scoop like this out of CF for your project.
all theory.
#32
I too was surprised with the fit of the shape. Bart had this look on his face when he saw it too, then I put it on the car and he agreed there might be enough "roundness" to pass the mustard. The mini paint scheme helps too. On the final product the black trim and stem will be left clear carbon.
Bart, I didn't have a IC core laying around but my oem. From what I've read over the years, it is hard to beat anyway and for the purpose of mesurments it will do.I fully intend to use your type of upper duct as well as a lower one. By the way I got a 9 degree increase in the tilt, that alone should help the flow a bit!
#33
2) On the IC - a rework of the stocker is the way go. Lets hook up and talk and beers. A few degrees will definetly help "flow". I opted not to use a bottom duct for I wanted to retain the perceived benefit of the air hitting the top of the engine. There are two perceived benefits of a top scoop -
1) better seal than foam to the hood.
2) The tapered design should pressurize sooner and create a smoother air path.
#34
I was refering to the shape of the mirrors. I would have liked to see them oval style to match the roundness of the car.
as far as the air induction, I like what I see and am curious of how much more power you will get from the new part. are you going to post Dyno results? of do you have any already.
#35
I as said in the OP it was the "momorabilia" thing, and that is what the R10 mirrors are . Including the the blue mirror glass that my wife hates. And exepted the motorised fonction. My R8 wing got some very straight lines into the car and the mirrors seems to blend Ok with it now. Of course the new DOME car came out with oval mirrors, but it was too late, and exept for racing against it, I have no involvement in it . The Mini paint scheme realy make the shape stealthy, I think. I've been watching them driving in rain and it is amasing. The water witch was on the glass before moving, stay there absolutly still, until dry. There no swurling, no flying off, nothing !!!! There is no drag .
Can somebody please tell me how to download spell checking? I just got a new computer and it didn't transfert from the old one, and the icon is nowhere to be found .
#36
I am right now looking for a 5 to 6 channel data logger. just to make sense of my experiments. I do not believe in dino numbers as a proper tool to judge IC efficiency. With my system I would need to dino with the hood shut, and 65 mph fans,. It ain't gona happen! It will never show me heat soak, recovery, and it will not give me any valuable h.p. numbers.
I plan on geting deltas 1st. Then do the maths.
My car is a "dino queen", 7 times so far, I've learn a few things .
#37
#38
#40
#42
#44
I could use the combined geniuses here for a bit of problem solving...I've been tripping the CEL recently and the same frustrating codes keep popping up...
1-#3 cylinder misfire detected
2-fuel too rich in bank detected
I've replaced the coil and plug wires and the codes still pop up. All the plugs look perfect so I'm suspecting that my #3 injector is failing...you guys concur?
#45
Hey, Sid, what if you swaped #2 and #3, see if you get that code on the new cylinder? . I don't know s..t about injectors but I slept at the "Inn" last night .
I have been looking for a boost leak for the past 2 weeks, could not find any. So this morning I whent to Minspeed and got one of Pete's by-pass valve, just for the hell of it I also bolted on the 59mm throttle body that I had gathering dust in the shed. Not only did I get my boost back but the needle gets up there in a hurry
#46
...no problem spanking new Mustang GTs at Woodward tonight...must be workn...
#49
would one of these work?
http://www.race-technology.com/data_loggers_8_920.html
~40lbs off the top of the car sounds good to me
#50
