Interior/Exterior Correct Me If I'm wrong in HID Retrofitting
I have a 04 MCS with Halogen lights and looking for a good way to get HID's without blinding others.
I know about the OEM way...getting the OEM 02-04 or 05+ Xenon kit and then retrofitting them, but it is way too expensive for me. I also like the aftermarket look more.
Is it possible for me to...
Purchase a eBay Halo Head light Kit (NON-HID) ($160 to 170)
Purchase a TSX HID Projector Housing or any other HID Projector Housing that could fit. ($50 to $60 just the housing)
Purchase a aftermarket HID conversion kit (S2R Kit). ($80 to $150)
And put that all together? From all my research from NAM. I know a HID conversion kit behind a halogen projector would scatter the light rendering it ineffective. So if I was to change the halogen projector to a HID projector and use an aftermarket HID kit, the light wouldn't scatter? Am I correct? or just dead wrong?
Another way I thought of was just buying an entire TSX HID Kit (with ballast, bulb, housing and etc.) and retrofitting that into my current OEM 04' head lights but the entire TSX HID kit would run be anywhere from $500 to $600. And I would much rather do that on aftermarket headlights with the halo.
Any opinions. Comments? I did a lot of searching before I wrote this thread. Any questions I ask, I actually tried to answer through searching before I posted.
Honestly, I would keep an eye out for '03/'04 Xenon Headlights on ebay, or here. I recently upgraded to '05/'06 Xenons, and sold my old style xenons for $150.00
If anything, I would suggest finding something designed to project Xenon light.
If you are considering the TSX projectors, have a look at Burley's thread. There is a lot of work that has to go into retrofitting, plus, you have to find something to work as a shroud. Burley's thread gives a lot of important information.
https://www.northamericanmotoring.co...ght=Burley+TSX
Unfortunately, good lighting does not come cheap, and it is something that you really shouldn't cheap out on.
-Chase
-Chase
Burley's thread was what inspired me to do this. I actually PM'ed burley with some questions.
I don't like the style of the olden Xenons. The 05+ Xenons are too expensive and I really dig the look of the aftermarket projector lights. The TSX projectors are not cheap. I might try to score the OEM ballast and bulb for them, if not then a aftermarket S2R HID kit.
Purchase a aftermarket HID conversion kit (probably H7). ($80 to $150)
Yeah that makes sense. But what I've learn from another member here (burley) is that some projectors are sharper and clearer than others. Also a lot of members claim that these after market headlights are good for HID Xenons because the stock projectors are crap.
If nobody has any other input, I guess I'm just going take the risk and try this out for myself when Jan. rolls around.
My steps would be (in case any one is following)
-Buying the after market head lights and take it apart.
-Measuring the projector sizes and hopefully the TSX would fit them as the TSX is known to be good projectors.
-Buy the best fitting HID Xenon projector.
-Buy the right HID conversion kit that fits the projector...S2R, H4, H7...etc.
And then put it all together. Hopefully that would work out...
you can buy the aftermarket halo projector lights that have the proper rounded glass on it.
Then put an HID kit in. it will be legal once they are alligned properly and will light up the road properly BUT you wont have the washers!!
Not having the washers is illegal in the UK, would someone like to shed a light on this matter in the states??
Examples of aftermarket projector retrofits that look very clean and OEM
wow those lights on the subie looks great! did you do those yourself?
From what I've seen, the OEM HID's on a MINI don't look sharp enough for me. Also I think it's the third time I mentioned...I like the aftermarket look? The 05+ look isn't bad either, but I'm not going to spend that much money on headlights that I wouldn't be happy with. The aftermarket headlights are already joey modded which is a big plug. I just have to retrofit the TSX projector (if it fits, I'm hoping it does) and black out the rings.
This is what I gathered, and hopefully I can put it all together and make it work. Does anyone have any opinions on why this won't work or anything I should keep in mind with this?
Joey Modded aftermarket Halo Projectors
http://www.neweggmall.com/Product/20...0/product.html
TSX Projectors:
http://cgi.ebay.com/ebaymotors/ACURA...Q5fAccessories
D2R HID conversion kit:
http://cgi.ebay.com/ebaymotors/Slim-...Q5fCarQ5fTruck
Am I missing anything else?
TSX Projectors:
bbak11010
09-07-2015 08:08 PM
bbak11010
09-07-2015 08:03 PM
