Interior/Exterior Rear Foglight-Friendly Brake Light Mod (pics)
Old 11-16-2010, 10:56 PM
ChrisWyso's Avatar
ChrisWyso
ChrisWyso is offline
Having a problem
Hey all, I see it's been a little while since any new posts here, but I thought I'd give it a try.
I tried this mod a couple of days ago and had a problem. Lemme start by saying I have a '06 Cooper S. So I got the diode into place in the passenger side harness connector at tested the brakes. Well, instead of getting the upper fogs on with the brake lights, the brake lights came on along with my reverse lights. Now I say lights, because on both the driver & passenger side, the brake and reverse lights were on, but I only had a diode in the passenger side, I hadn't even opened the driver side access.
So did I just mess up and not really have it in pins 1 & 4? Or is there something different about my year and wiring? Also, is there docs on what the wiring pin outs are for the rear passenger harness connector?
Thanks much!
-Chris
  #77
Old 11-17-2010, 05:41 AM
CooperT's Avatar
CooperT
CooperT is offline
Chris,
I don't have the wiring diagram, but aren't the rear lights different on '06? With the fog being a single above the exhaust? The '04 and earlier had dual fogs below the turn signals with the backup light above the exhaust.
Tim
Thanks much!
-Chris
  #78
Old 11-17-2010, 08:19 AM
paulgraz's Avatar
paulgraz
paulgraz is offline
Chris - this isn't going to work for you. This particular setup was designed for the early cars - 02/03/04. I forget when the tail light design changed, but by 06 the rear foglight was a single lamp in the center. And it's probably not even a good idea for you to do this mod on a car with a single center rear fog light, drivers behind you will just get confused.
  #79
Old 11-17-2010, 08:25 PM
ChrisWyso's Avatar
ChrisWyso
On the '06 S models, there's reverse lights in each tail light. I believe the base Cooper uses the single reverse down center.
I do have upper lamps in each tail light, but I guess they're just used for signaling when you hit the trunk release on the fob.
Thanks for the clarification all!
  #80
Old 11-18-2010, 08:59 AM
Walnuts's Avatar
Walnuts
Walnuts is offline
These last few posts make no sense. I have a 04 s and my reverse light is down above my tailpipes. My friend has a 06 s and his are in his tail lights.
07-16-2020 12:54 PM
emulajavi
12-24-2018 09:15 AM
Terry Gallentine
08-11-2015 03:31 PM
08-07-2015 08:02 AM
Quick Reply: Interior/Exterior Rear Foglight-Friendly Brake Light Mod (pics)
