Yea, the painter had the car taken apart so I thought about painting the door handles but in the process of sanding the Brushed Aluminum came out of no where and I stuck with it. I did the eye lids as well
Very cool brushed Aluminum look. Was it a wet sand with 2000 grit ?
With respect to rear window dirt buildup it would be interesting to see if there is any difference w/o the wing attached. Are you thinking of getting a mid-wing set up or going stealth ?
Thanks man, I used about 300 grit sand then used some scotch brite to go over it a little to give it the brushed effect.
And about the wing, I haven't had the chance to wash it. It came out of the body shop dirty. I think I might just keep the wing off, a lot of the wings on the market are way over priced.
Looks very nice, I do like the wingless look Just out of curiosity what had happened to the bonnet? The headlight looks pretty wrecked in that photo.
I should have explained the pictures, the ones with the strips are of the car before someone hit me. The new pictures are after replacing the hood and light
ive had no wing on my car for about 2 years and the buildup is the same
