Interior/Exterior help please: wegdes in the bumper cooperS
The parking lights in the bumper does not match the color of my HID's so want to change them to Piaa superwhites.
I breifly checked the owners manual, but could not figure out how to
remove that lens to replace the wedge. I have the factory aero kit.
Which wedges are you guys using to match the HID color? are those 192 size?
thanks :smile:
thanks :smile:
thanks for the info...but how do i get to that plug? do i need to remove the front bumper? is it accessible after opening the hood?
front of car:
( )______( ) <= headlights
O______ O <= these are the ones I want to get to.
o_______o <= foglights
_________________
2003 Cooper-S IndiBlue/Black Top: #1, #2, #3, Factory aero kit, R90 wheels.
front of car:
_________________
Open the the hood and you will find the access hole on either side of the car for those lights behind the bumper, You will see some small wiring harnesses, and two sockets, one large and one small. The large one is the amber turn signal, the small one is the white marker light. I have big hands but am still quite able to remove either socket. Twist the socket counterclockwise (looking from behind) and then pull it towards the back of the car to remove it. Pull out the old bulb, push in the new one and reverse what you did to get the socket out. Repeat for the other side, and you are done.
Before you do a replacement, why not try the optical blue film treatment?
https://secure2.websitecomplete.com/...d.asp?prod=148
all for under $15.
all for under $15.
07-16-2020 12:54 PM
bctf1
08-06-2015 12:55 PM
