Interior/Exterior D1S Bulb
Not sure what you're looking for but check out the Philips Ultinon bulbs (5800K). It's what comes in the high-end BMWs, Mercedes-Benz, etc. Nicest color output IMO.
Haven't really decided on a color output yet, but I'd prefer if a place had multiple color ranges so I can decide what to go with...
The colour output is created by the "cutoff" on the projector. When you want the colour output to be created by the bulb (not necessary for a projector, but necessary for the glarey riced out honda civics) you then look for a higher colour temperature.
You could look at modifying the shield in the projector or spacing the bulb to create a more purple/blue cutoff.
X 2 on the bulb, you are looking for a D2S, not a D1S. D1S is used on the second gen mini, it has the ignitor attached to the bulb.
4300K is stock on most luxury brands. It has the most lumens (light output) and is what i would highly recommend.
If you guys need further confirmation I can take pictures of it.
Anyways, I'm definitely not looking at purple or any of those ricey colors, but I am trying to find a nice balance between white and blue...
As far as the cutoff goes, I've already planned on modifying the shield inside the projector housing once I get started on my Joey mod.
I was merely stating the fact that the information given to me was incorrect (that I would require a D2S instead of a D1S). Thanks for the sarcasm though, rather than moving on with the topic at hand...
My car uses a D1S, not a D2S. My bulb has the igniter and the bulb built together. The version I have has superseded the older D2S style housing...
Also, the D1S bulb has not superseded the D2S. D2S is still in use by many car manufacturers.
Well, you deserved the sarcasm as you brought it first:
You know, since you really needed the rolling eyes smiley. You could have posted that you *know* your car takes D1S and not D2S as in your signature you have an '05, so as friendly NAM people, we just made sure you knew what bulb you needed as we assumed you have the stock HID projectors!
My statement was regarding the R53 projectors about the D1S superseding the D2S, which is true.
Anyways, I've still been searching for some HID bulbs and I'm still having a hard time finding a company with a broader range of HID colors.
Yeah, it is going to be hard to find other brands as OEM is 4300K, so major manufacturers will only make that as they know it's best (some major brands will make a 5000K). If you find an unkown brand or a cheaper brand, usually made in Asia, there are going to be other things to consider. Quality of components and distance of the xenon light source to the base of the bulb (this will affect output of the projector). I truely think you would be happy with a stock bulb by a quality producer (Phillips, Osram, etc) and the colour modding would get the cool colour you are looking for.
10-01-2015 12:13 PM
09-29-2015 12:17 PM
09-29-2015 12:16 PM
09-29-2015 12:11 PM
