Interior/Exterior Wanted - beltline blackout picture of finished ends
on
I'll upload a photo in a couple hours,
But I go over the rubber endcaps so that the vinyl matches the end of the cap. I found that when I didn't the vinyl has a tendancy to shrink just a tad and shows about 1 to 2 mm of chrome (which is totally noticeable to someone who is super complusive and a perfectionist when it comes to my cars).
BUT, the additional step I did was to let it sit for a day to allow for vinyl to shrink, then go back and trim off excess at the point where the chrome and plastic meet.
not sure if you know this, but I'd recommend to not apply the vinyl over the top portion of rubber ...there won't be enough vinyl to get a good grip and you'll end up w/ frayed edges of vinyl at the top. Best to line up the vinyl top where the top of thte chrome meets the lower portion of the top piece of rubber. YOu'll end up w/ about 6mm-8mm of vinly over the lower portion of rubber (below the chrome) yet you can tuck that in w/ a plastic scraper ...plus that 6-8mm of vinyl will give a better grip at the bottom and stay in place.
on
If in direct sunlight or on hot days the tape will stretch itself out too....
I guided mine so it was just under the top black ridge so it doesn't bunch up and let the little excess go down and under.
Cut tape off square beyond ends while applying and then go back with razor blade and make angles. Helps if you indent tape first with fingernail so razor blade has a line to follow belt line's end cap.
Thought a photo using another color may help ya better to see end caps...
IMG_0494.jpg?t=1241550446
IMG_0493-1.jpg?t=1241550546
on
for the tops/bottoms use a small hook or toothpick etc and sweep it from side to side pulling the rubber up and over the top and bottom section of the tape.
and no afaik you can not pull it off and spray it - and don't plastidip it b/c that stuff is liquid and gravity tends to pull it downward at 32 ft/sec^2
Go for the PlastiDip. I did a test with the belt on my boot. It is easy you just have to do it on a very calm nice day. I live in CT and since I did the test we have had rain 90% of the days since. As soon as it get nice again I'm going to finish the rest of the belt line. The whole tape thing is ok but the ends just look like crap for me. I want it to be clean.
I just plastidiped my side scuttles and gas cap and is so pleased on how super easy and super good it looks!
Im probably going to do the beltline tomorrow with plastidip. I decided to give the vinyl a second chance today but it really looks awful.
Hey, toolazyforalogin, have you tried to take the beltline off? Is it easy to get back on? Im really reluctant because i feel like im not going to be able to get it back on.
I'm really thinking about Plasti-dipping the beltline, but I'm really paranoid about it getting all over the glass and the rest of the car without me noticing right away. It sucks that it can break so easily if you try to pop it out.
on
Belt line removal
I have not removed all the beltline, but most of it comes off pretty easy.
If you go to this link and open the pdf file there are pictures on how to remove.
https://www.northamericanmotoring.co...tall-gen2.html
Interior/Exterior DEPO/Helix Projector Headlights Installed
Alkaidovich
01-30-2021 01:35 AM
07-16-2020 12:54 PM
iamcamkeenan
08-10-2015 03:31 PM
