Paul at Marshall says the next sample faces will arrive in the "next 3-5 business days." Anyone holding their breath should take one before they turn purple.
Hey Steve, any word on the non-Mini gauges that have stepper motors? I'm at the point where I need to buy these things now so I can finish putting my oil cooler setup together.
If they are still at least a month or so out, I'm just going to buy the old style and swap over at some later date.
Hy every one can you tell me wat's the cost for the Marshall Inst. gauges that fit the MCS R56. I currently have the ALTA Boost & Water Temp.
Can I use the ALTA Gauges hook ups & wires. Thanks Don
Hi all can you tell me the cost of MARSHALL GAUGES for my MCS R56 I currently have ALTA installed BOOST & WATER TEMP can I use ALTA hook ups & wiring. Thanks Don
I can't even guess at the time frame anymore. The SCX Pro stepper versions are available in oil pressure, water temp, volts and fuel level. They would have to be redialed in silver since they are only black now. Oil temp with steppers is still odd. Paul says they don't have anything in the 140-300F range, but that they have 100-260F but that they need dials. I will have to call him to clarify what that means.
Are the marshall gauges the same size as the gauge kit that MINI has on each side of the tach? That mount would resolve an issue for me with mounting of the gauges and another item by the tach.
Also, in looking at the pictures I noticed that the gauges are not labeled with their function as the other SCX gauges are, will this be done with the production units?
Looking forward to getting these installed before the next HPDE.
