Interior/Exterior Matching factory gauges
#301
Higher resolution image
http://6qygkg.bay.livefilestore.com/...b/STP_9481.JPG
#302
#303
they don't match each other or the rest of the gauges.
https://www.northamericanmotoring.co...s-for-jcw.html
#305
and they look like @ss !!
#306
Steve
#308
I'll try to keep this on the current page of this thread.
Group Buy Prices:
Vac/Boost, 30" Hg - 30 PSI (mechanical) $47.50
Oil pressure, 0-100 PSI (electric) $59.50
Oil pressure, 0-100 PSI (stepper) $83.50
Water temperature, 100-260°F (electric) $53.50
Water temperature, 100-260°F (stepper) $77.50
Oil pressure and water temperature gauges include the sending unit with 1/8" NPT connection.
Stepper motor gauges have peak recall and warning functions.
Shipping is $10 in the lower 48 states. Hawaii, Alaska and non-USA destinations will be determined individually.
The CravenSpeed mounting and adapters are going to be 10% off list price for this group buy. If you have any other CravenSpeed requests, I will offer 10% off those items during this group buy. Anyone with existing CravenSpeed mounts should be aware that the new mounts are powder coated instead of anodized so they won't match perfectly. I still have a few anodized pieces in stock so let me know.
Gauge Cup (52mm) gen1 and gen2 $49.00
Gauge Cup (dual 52mm) gen1 and gen2 $71.00
Bracket X (gen1) tach mount for cups $30.00
Bracket ZL (gen1) cup mount for chrono/nav $40.00
Bracket ZR (gen1) cup mount for chrono/nav $40.00
Bracket A (gen2) cup mount $45.00
Bracket R (gen2) single cup mount $40.00
Cup Caps (52mm) caps for back of cups $26.00
Tapless Adapter (gen1) oil pressure adapter $44.00
Tapless Adapter (gen2) oil pressure adapter $67.00
Hot Link (gen2) water temp adapter $54.00
PSIClone (gen2) vac/boost adapter $35.00
Please e-mail your billing and shipping addresses to gaugegb@blackoaks.com. Be sure to include your phone number and the gauges and mountings you want to buy. I will e-mail you an invoice for you to OK and then you can call me or vice-versa for the CC info. Some have e-mailed me the CC info which is OK if you are comfortable with that. I do not bill until I ship. I have not received the gauges yet so I expect to start shipping next week. You can call me if you have questions at 559.320.0004 Thanks.
Steve
Group Buy Prices:
Steve
#309
#310
Thanks Steve for organizing this for us!
I received my gauges from Steve today and thought I'd take a few pics for everyone.
Water Temperature Gauge
Vacuum/Boost Gauge
Oil Pressure Gauge
In the pods...
What to put in the 4th spot? Hmmm....how about this?
The full set of photos are here: http://www.flickr.com/photos/25639646@N02/sets/72157622288237565/
More photos of them installed to follow...
Cheers,
Tom
Vacuum/Boost Gauge
Oil Pressure Gauge
In the pods...
Cheers,
Tom
#312
on
Steve,
Just replaced my SCX Marshall gauges and the font looks great Not having the label such as temp/boost etc makes the gauge look clean just like the Mini Gauge they don't need a big sign to tell you its a speedometer or a tachometer very small label for what the gauge is. Color and performance is great. The mechanical Boost/Vac and the electric temp make a great combo and the price is excellent. Thanks for taking the time to organize this.
#313
Take a look here: Custom Thin V1 Remote Display
I then took a Craven Pod Cap and cut out a section to mount it on. It needs a bit more work, but it fits well.
Cheers,
Tom
Cheers,
Tom
#314
Steve,
from the front & the sides would be awesome ! thanks
#318
on
#319
Cheers,
Tom
Cheers,
Tom
#321
on
Three wires? I terminated the white light illumination wire. The Orange light wire went to the gray red by the DSC for light control this way you can control the light and not have the gauges at full bright when you have dimmed everything else. Then the +12V went to a switched power line that is on when the car is on. Lastly the ground to a ground to make the gauge work. Hope that answers the questions your having.
#322
on
You terminated the white wire (put a connection on the end of it) - but what did you connect it to?
Why does the gauge need a constant 12v+ that is what I want to know. Right now I connected the three wires and soldered a single wire off of them. Both the white and amber lights (yellow orange wires) should come on at the same time (when the lights are turned on)
#323
on
#324
now all you need to do is swap in the JCW wheel to complete your 'drivers' cockpit.
