Interior/Exterior Matching factory gauges
#401
I'll try to keep this on the current page of this thread. Group Buy still on throught the end of October.
Group Buy Prices:
Vac/Boost, 30" Hg - 30 PSI (mechanical) $47.50
Oil pressure, 0-100 PSI (electric) $59.50
Oil pressure, 0-100 PSI (stepper) $83.50
Water temperature, 100-260°F (electric) $53.50
Water temperature, 100-260°F (stepper) $77.50
Oil pressure and water temperature gauges include the sending unit with 1/8" NPT connection.
Stepper motor gauges have peak recall and warning functions.
Shipping is $10 in the lower 48 states. Hawaii, Alaska and non-USA destinations will be determined individually.
The CravenSpeed mounting and adapters are going to be 10% off list price for this group buy. If you have any other CravenSpeed requests, I will offer 10% off those items during this group buy. Anyone with existing CravenSpeed mounts should be aware that the new mounts are powder coated instead of anodized so they won't match perfectly. I still have a few anodized pieces in stock so let me know.
Gauge Cup (52mm) gen1 and gen2 $49.00
Gauge Cup (dual 52mm) gen1 and gen2 $71.00
Bracket X (gen1) tach mount for cups $30.00
Bracket ZL (gen1) cup mount for chrono/nav $40.00
Bracket ZR (gen1) cup mount for chrono/nav $40.00
Bracket A (gen2) cup mount $45.00
Bracket R (gen2) single cup mount $40.00
Cup Caps (52mm) caps for back of cups $26.00
Tapless Adapter (gen1) oil pressure adapter $44.00
Tapless Adapter (gen2) oil pressure adapter $67.00
Hot Link (gen2) water temp adapter $54.00
PSIClone (gen2) vac/boost adapter $35.00
Please e-mail your billing and shipping addresses to gaugegb@blackoaks.com. Be sure to include your phone number and the gauges and mountings you want to buy. I will e-mail you an invoice for you to OK and then you can call me or vice-versa for the CC info. Some have e-mailed me the CC info which is OK if you are comfortable with that. I do not bill until I ship. I have not received the gauges yet so I expect to start shipping next week. You can call me if you have questions at 559.320.0004 Thanks.
Steve
Group Buy Prices:
Steve
#404
Email sent!
I just found this thread, and I'm definitely on board with the current and planned gauges. I've been holding off on extra gauges for 3 years because of the crappy-looking choices out there. I also would like to see an ammeter added to the future models proposed.
Question:
Has anyone tried to swap these into the factory gauge pod that goes under the radio? (This one). I'm not sure what size those gauges are.
Question:
#405
on
Email sent!
Question:
Question:
#406
Email sent!
Question:
Question:
#407
I know that Steve has been working with Paul to add more gauges with that in mind and the options to add more then just the two that are down below your eye scan I would go with the more is better approach. Look in my gallery lots of pictures of them mounted on an R56 color and look they match all the Mini's perfectly.
#408
on
I asked because I already have the OEM voltmeter & oil temp gauges down there, but I would like to replace them with the Marshall ones (if they ever make them). Actually, my plan is to have the oil temp, oil press, coolant temp, and boost gauges up by the tach, then put voltmeter and ammeter down under the electronics stack.
#409
#410
#411
I measured the heater hose for the water temp adapter again and discovered that it is 5/8" inside diameter. I previously measured the stretched hose at 3/4" So below should be the correct adapter.
http://www.autometer.com/cat_accesso...il.aspx?vid=49
#412
#415
Steve
#416
#417
#420
This may have been covered, but there is a lot of data spread throughout this thread. I am interested in the basic electric water temp gauge if it works with the factory dimming circuit. From reading it appears the stepper gauge has issues and needs a separate dimmer. Does the basic electric water temp gauge also need a separate dimmer.
Also a previous post by the seller indicated the water temp gauge would not fit inside the Craven Pods. How has that worked out for those that have done the installation on an R56?
#422
on
Sorry I missed the question about the water temp gauge I ended up cutting the two posts that are used to hold the gauge into a dash using the factory install. I also ended up painting the back of the gauge with black paint to take away from the white back. Look in my gallery and you will see my gauges installed.
#423
The Craven cup fitment issue must only apply to the basic electric water temp gauge, and maybe other basic gauge versions. FWIW, I procured the stepper motor versions of the oil pressure and water temp gauges and I have plenty of clearance left for the cup caps on both (after cutting off the two dash mount posts, as TC mentions). This is an R50/R53 install; not sure if the cups are different for the R56. In fact, I plan to hide the programming button behind the gauge and under the cup cap -- I can always pull it out later to change the set points if necessary (don't figure I'll be doing it very often).
#424
So it appears if I get the step gauge water temp there are dimmer issues, if I get the basic gauge it does not really fit. Then I am not sure if i need the "Hot link (gen2) water temp adaptor for $54.
It appears the cost would be $228. Basic Water Temp gauge $53.50, Shipping $10, Gauge Cup $49, Bracket single $40, hot link $54 plus a hose connector for the sensor $30 from Summit Racing.
Now I am leaning towards the overly expensive but versatile PLX DM-200 OBDII gauge for $380 (plus pods) since it can be programmed via a laptop to look exactly like a MINI gauge, plugs into the OBD port and can show much more in one gauge.
#425
