Interior/Exterior Matching factory gauges
Old 12-20-2009, 05:22 PM
JIMINNI's Avatar
JIMINNI
JIMINNI is offline
Originally Posted by Tron Chief
I think SRTech has a multi gauge R53 setup that shows the attachment options next time I'm in the shop I will take a picture. I plan on using my existing two cups on one side (right) and putting a double on the left. Where as I already have the two singles might as well use them. The other option if I'm not happy with the look is to go to two double cup holders one for the right and one for the left
Steve also now has that iPhone mount that attaches to the back of the gauges as well, kinda interesting.
  #527
Old 12-20-2009, 06:02 PM
anitan1's Avatar
anitan1
anitan1 is offline
Hey JIMINNI, do you have a link to Steve's site, his stuff, etc. The iPhone mount sounds cool. I wonder if he has a Blackberry option...
  #528
Old 12-20-2009, 06:08 PM
JIMINNI's Avatar
JIMINNI
JIMINNI is offline
The shop link is in my sig, but I don't think Steve has updated it yet. I'm sure we can get you a pic though Here is the actual link to Craven, which is what it is. Just remember I believe Steves group buy is still going on.
http://www.cravenspeed.com/index.php...ug=ipod-cradle
  #529
Old 12-21-2009, 08:16 AM
SRTech's Avatar
SRTech
SRTech is offline
I wish CravenSpeed would tell me when they get new products. I will have the Blackberry Curve mount in stock in a couple of days. Remember that the CravenSpeed mounts only fit uncovered phones. The group buy goes until the end of this month.
Steve
  #530
Old 12-29-2009, 04:02 PM
Tron Chief's Avatar
Tron Chief
Tron Chief is offline
Steve could the dual pod holder be modified to add a peak recall switch in the center section?
  #531
Old 12-29-2009, 05:56 PM
Thomas S's Avatar
Thomas S
Thomas S is offline
I'm not Steve, but if you're handy with a mill that should be feasible. You'd have to hog out a lot of metal from the back side of the pod, which is made out of a chunk of solid aluminum billet. Not a bad idea, really.
Tom S
  #532
Old 12-30-2009, 08:02 AM
SRTech's Avatar
SRTech
SRTech is offline
Tom S
No metal to "hog out" since it's open behind. You would just have to drill a hole through about 3/16" thick metal. There is enough space in the cavity in back to mount the switch. Unfortunately, there isn't enough room for the dimmer.
Steve
  #533
Old 12-30-2009, 08:07 AM
anitan1's Avatar
anitan1
anitan1 is offline
Hey Steve,
Why wouldn't that set up (shown in post 531) have worked for my Blackberry mount?
  #534
Old 12-30-2009, 08:16 AM
SRTech's Avatar
SRTech
SRTech is offline
Hey Steve,
It's not stable enough. I have another method using the bracket-z and i-bone from Cravenspeed. Including the Blackberry mount it would cost about $100 to do which is a little expensive, but works well and is secure.
Steve
  #535
Old 12-30-2009, 08:53 AM
SRTech's Avatar
SRTech
SRTech is offline
BTW, the chrome rings fit fine in the dual pod mount. I believe there was a post earlier in this thread that said they didn't fit. Pictures to come...
Steve
  #536
Old 12-30-2009, 09:14 AM
SRTech's Avatar
SRTech
SRTech is offline
  #537
Old 01-03-2010, 04:57 AM
Mike S's Avatar
Mike S
Mike S is offline
Just a quick question, how come the stepper gauges need 12V+ source when ignition is on and one permanent 12V+ source as well? Just curious as my current gauge(other make) only requires the 12V+ when ignition is on.
  #538
Old 01-03-2010, 08:13 AM
rjb's Avatar
rjb
rjb is offline
Paul from Marshall could probably give you a better answer, but I believe the 12V+ directly to the battery is for the recall function. The gauge will work without it if you do not want the peak recall function, or the ability to dim the gauge lighting. The gauge lighting is dimmed via varying the voltage to the 12V+ (Ignition) switched signal. When this voltage drops (for dimming) it does not provide enough voltage to power the gauge.
  #539
Old 01-03-2010, 11:10 AM
Mike S's Avatar
Mike S
Mike S is offline
Thanks rjb. I am trying to avoid anymore wiring than I would have to. I will not be using the dimming feature or the recall function. So I was just wondering if I could leave that out altogether. I guess I will wait for Paul or Steve to confirm.
PS. The gauges are awesome in appearance!
  #540
Old 01-03-2010, 06:23 PM
JIMINNI's Avatar
JIMINNI
JIMINNI is offline
Just changed up my setup. Went to a dual gauge setup on the left side, used two single pod's and a "y" connector, I like it better than the dual pod setup. On the right side I installed my Scangauge with Cravens new Scangauge bracket. I think it came out nice?
  #541
Old 01-03-2010, 07:30 PM
onefish2's Avatar
onefish2
onefish2 is offline
Looks great. I have been thinking about getting this setup. Can you comment a bit more on the Craven Speed Scangauge bracket?
  #542
Old 01-03-2010, 07:31 PM
Tron Chief's Avatar
Tron Chief
Very nice look to this setup
  #543
Old 01-03-2010, 08:17 PM
JIMINNI's Avatar
JIMINNI
JIMINNI is offline
Thanks. It has a long arm that mounts to the Craven bracket. Then you bolt on the Scangauge bracket, it is made specifically for the Scangauge. It is very well made I might add a gauge above the scangauge eventually.
  #544
Old 01-03-2010, 08:19 PM
JIMINNI's Avatar
JIMINNI
JIMINNI is offline
Old 01-03-2010, 08:21 PM
Tron Chief's Avatar
Tron Chief
You could always put a phone or glass case holder
  #546
Old 01-04-2010, 09:02 AM
SRTech's Avatar
SRTech
SRTech is offline
If you don't require lighting adjustment or peak recall, you can just connect the light lead and power lead to the same 12V switched power source.
Steve
  #547
Old 01-04-2010, 09:41 AM
Mike S's Avatar
Mike S
Mike S is offline
Thanks Steve! I'll do that!
  #548
Old 01-06-2010, 09:06 PM
Blu_Pug's Avatar
Blu_Pug
Blu_Pug is offline
So, December was a nightmare at work and I failed to keep up with this thread. Any chance this buy can be extended by "popular demand"? ;-)
Thx.
Alan
  #549
Old 01-07-2010, 08:31 AM
SRTech's Avatar
SRTech
SRTech is offline
Thx.
Alan
Give me a call.
Steve
  #550
Old 01-07-2010, 08:42 AM
joe_bfstplk's Avatar
joe_bfstplk
joe_bfstplk is offline
I got my gauges on Xmas eve, and they look fantastic.
Now I just need to save up my spare change for the pod kit....
C ya,
Dutch
Quick Reply: Interior/Exterior Matching factory gauges
