Interior/Exterior Matching factory gauges
Old 05-02-2010, 07:45 PM
ron-s mini's Avatar
ron-s mini
ron-s mini is offline
Installed with a Bracket "W" with dual pod cups, in a horizontal fashion above the tach.
  #627
Old 05-18-2010, 08:42 PM
LetsMotorR53's Avatar
LetsMotorR53
LetsMotorR53 is offline
Definately considering these gauges. Yours look great! I was curious though, the ones that I am seeing on the website do not read "boost" or "oil" on the actuall gauge face like yours, not sure why thats different. I was thinking about using the same two gauges that you did. Was the install difficult? Was installing the mechanical boost gauge tricky? Thanks!
  #628
Old 05-18-2010, 08:43 PM
LetsMotorR53
  #629
Old 05-18-2010, 09:08 PM
LetsMotorR53
What exact bracket/cup combination from cravenspeed are you using? looks like theres many to choose from, I want to be sure Im getting the right ones for my R53. Could you post those links?
  #630
Old 05-18-2010, 09:41 PM
JIMINNI's Avatar
JIMINNI
JIMINNI is offline
Originally Posted by LetsMotorR53
Definately considering these gauges.the ones that I am seeing on the website do not read "boost" or "oil" on the actuall gauge face like yours,
I love mine Where are you seeing this? "on the actuall gauge face like yours,". Are you talking about ron-s mini's picture?
  #631
Old 05-18-2010, 09:55 PM
Tron Chief's Avatar
Tron Chief
Tron Chief is offline
I had the non Mini Gauges in my car for a few thousand miles then when SRTech and Marshalls gauges came out with the gauges that were designed to match our interior went ahead and purchased a set of Mini Gauges. Just like the Tach does not have anything huge after all its our car and we know that its a tach. Now with four gauges I have no issues with the markings and like the balanced look.
  #632
Old 05-19-2010, 07:10 AM
LetsMotorR53
I was talking about fingershooter's pics. Some how I ended up on this page, https://www.northamericanmotoring.co...ry-gauges.html
  #633
Old 05-19-2010, 07:35 AM
JIMINNI's Avatar
JIMINNI
JIMINNI is offline
Don't think any of them come labeled any more? Give SRTech a call 559-320-0004, as he is the exclusive dealer for the Marshall gauges.
  #634
Old 05-19-2010, 08:37 AM
anitan1's Avatar
anitan1
anitan1 is offline
You have to read through the thread. The pics you refer to are the first iteration of the gauges. The original author of this thread worked with Marshall to develop a set of gauge faces that look more like original equipment than other gauges. The words on the gauge face were eventually removed to keep with the "factory original" theme.
  #635
Old 05-29-2010, 05:37 PM
JuanPabloPWR's Avatar
JuanPabloPWR
JuanPabloPWR is offline
[SIZE=3]Hi guys, me name is Juan Pablo, I'm from Argentina, I'm thinking of buying these gauges, where I can get installation instructions?[/SIZE]
  #636
Old 05-29-2010, 09:03 PM
JIMINNI's Avatar
JIMINNI
JIMINNI is offline
Just talked to SRTech, he said he will get back to you Monday
  #637
Old 05-30-2010, 08:20 AM
JuanPabloPWR
Thanks men
  #638
Old 05-31-2010, 09:05 AM
SRTech's Avatar
SRTech
SRTech is offline
Installation depends on what gauges, what type of gauges, what MINI and how you want the lighting to work. There is a lot of info in this thread which will give you an idea of what you might want to do.
Steve
  #639
Old 06-06-2010, 12:22 PM
SMOG's Avatar
SMOG
SMOG is offline
Removal socket & wrenches
Originally Posted by Clubmaste00
Steve
A couple of things about the install that I'll mention just for future ref. My OEM sender was installed so that the release catch for the wire connection was underneath the body - took a mirror and a dental pick to release it. I do not believe anyone has mentioned that a 7/8 deep well socket is needed to remove the OEM sender (at least that is what I needed) and that the body of the tapless connector takes a 1' wrench. If you are doing this yourself it would not hurt to have an extra O ring on hand for the tapless connector - where it installs into the head - the O ring is a number 114 - Since I was having problems getting the ports in the tapless connector to quit leaking I had the fitting on and off a few times and it not hard to pinch the O ring if you do not make sure it is seated in the groove on the end of the connector.
I have an R-56 MCa, 2009 early in the year manufacture. I used, fits exactly, a 22mm deep reach socket for removal of the OEM oil sensor. The Gen2 Cravenspeed "Tapless Adapter", that I was sent by them, fits a 1-1/16" exactly. Thought this might be of use since there could be different sizes floating about.
Here is an attempt to show what I have done to date, check out my "Gallery" since I cannot figure out how to get photos into the Thread. Not complete, needs final fitting polishing and paint. The next step, which is in progress, is the wiring. More photos to come later.
Stephen
  #640
Old 06-13-2010, 10:17 AM
JumpingJackFlash's Avatar
JumpingJackFlash
JumpingJackFlash is offline
I did alot of research about four years ago on getting factory-match gauges. The only company that sold them at the time was Greddy. I bought the air/fuel and turbo (i.e. boost) warning gauges. They are almost a spot-on match. They were initially in my old '02 MCS. I finally got around to installing them in my '06 MCS about two months ago.
  #641
Old 06-13-2010, 10:35 AM
SMOG's Avatar
SMOG
SMOG is offline
They look good!
The Greddy gauges look good and have the correct night color
S.
  #642
Old 06-13-2010, 07:09 PM
JIMINNI's Avatar
JIMINNI
JIMINNI is offline
? They look ok and all.....but they don't really look anything like the OEM's.
  #643
Old 06-13-2010, 08:04 PM
SMOG's Avatar
SMOG
SMOG is offline
This is a gauge project on which I am presently working. Maybe finished tomorrow.
S.
http://www.mini4fun.info/09_MCa_Gaug...6_Photos..html
  #644
Old 06-14-2010, 12:18 PM
JumpingJackFlash
JIMINNI, that's what I had to work with four years ago. The current offer at the beginning of this thread would have made me reconsider my options back then. I spent countless hours searching and researching to find the GReddy warning gauges with a silver face and amber lighting. There are subtle differences with them. The one that stands out the most is there is a small amount of white light that emanates from behind the needle base. Yes, the needle sweeps are at a different angle. And the number indicators are at a different alignment. But there is no need to go out and buy more gauges when I already have some that are very satisfactory to me.
  #645
Old 06-14-2010, 05:48 PM
JIMINNI's Avatar
JIMINNI
JIMINNI is offline
No they look good I wouldn't go out and change them either. I am now looking for a AFR gauge and obviuosly nothing is going to look OEM
  #646
Old 06-14-2010, 06:50 PM
JumpingJackFlash
Yes, it's tough finding a good-looking AFR gauge. Only downside is it's a narrow band. Maybe one day, I will buy the central computer unit and connect them for some datalogging.
  #647
Old 06-24-2010, 01:06 PM
AA-MCS's Avatar
AA-MCS
AA-MCS is offline
Hi Guys,
I’ve had mine installed since November and am still happy with them. Funny thing happened June 21st (first day of summer) my temperature gauge went from reading ~220°f to about ~200°f. Today happens to be my one year anniversary with my MINI and had the scheduled maintenance done. I specifically asked them to check to see if the engine was running abnormally cool and the answer was that it was operating within acceptable range. My questions are:
Has anyone experienced such a drop in temperature?
Is the computer programmed to run the car cooler in summer months?
Could the gauge itself be the problem?
Is 200°f too cold?
Thanks in advance,
  #648
Old 06-24-2010, 01:20 PM
Gil-galad's Avatar
Gil-galad
Gil-galad is offline
Originally Posted by AA-MCS
Hi Guys,
Is 200°f too cold?
Thanks in advance,
A couple of additional data points may help the NAM trouble-shooters:
-- R53 or R56? (looks like the former from your avatar but too small to be sure)
-- Where in the cooling system is your sender installed relative to the radiator/thermostat?
  #649
Old 06-24-2010, 01:42 PM
AA-MCS's Avatar
AA-MCS
AA-MCS is offline
Gil,
It's an R56. I'm not sure where in the system it's installed as I didn't do the installation. It's on with a coupling sleeve I think going into the radiator. My problem is that it happened suddenly. FYI, it's stepper gauge.
Thanks,
  #650
Old 06-24-2010, 01:49 PM
SMOG's Avatar
SMOG
SMOG is offline
AA:
Mine has been running about 202 on the freeway with occasional swings (steady climb but not instant)to 225. In town I run 190 when the engine is warm. As you can see in my web link the sending unit is in the radiator hose coupling and NOT the surge tank.
S.
Quick Reply: Interior/Exterior Matching factory gauges
