Can you sign me up for a boost gauge?
What about an intake temperature gauge? That would be cool right?
Also a chrono package cravenspeed mount for the right side would be awesome. Thanks
Not likely on the intake temp gauge. Which boost gauge? Mechanical, electric or stepper motor? Don't ask the prices since Marshall hasn't set them yet. I'll add you to both lists. Thanks.
Well... just caught this thread! Sign me up for a vac/boost (elec/stepper) and water temp with the chrome rings and a craven mount.
Actually, is there a list of the gauges they'll make available? Those listed above were the gauges I would've ordered from MINI, but I could change me mind if I knew what's likely to be offered. Sorta like the idea of voltmeter or maybe oil pressure. It's kinda hard to track in 200+ posts on this thread. (Well that, and there's some laziness involved here too... ) I thought I saw that volts won't happen tho.
Anyone have pictures of Nav/Chrono with Craven ZR/ZL mount with gauges mounted lower left/right...their instructions show the gauges mounted high center...looks weird.
Cool is not even close to what your Mini will look like. The end product will make you proud
You can reverse the mounts to put the gauges down low, but then the steering wheel blocks their view. You can use the Flextension arms to move the gauges around, also.
I agree with PA-MCS,too bad these wont fit the vent gauge adapter at 1 5/8" Thanks Kullen for the picture. I need a boost and oil Pressure for my R53. Chrome!
Seankidd, I think you misunderstood, I dont want my gauge in the vent. I'd like it in front of my vent, beside my speedo. The picture Kullen posted looks like it sticks out too far. But I'm sure there's room for adjustment..
I can't decide, the brackets are expensive, and the left vent mount is obscured by the steering wheel, I'll probably make my own bracket or modify a pod, either way I need a boost guage...I've had a Bypass valve failure and recently a sc inlet gasket leak (didnt know I had one till I replaced the gasket and runs sooo much better.)
SRTech, put me down on your list, too, for chrome trim water temp & oil pressure gauges, plus oil pressure adapter and CravenSpeed mounts. 2009 R56. Danke.
Got it! What about the water temp adapter? Thanks.
The first dials came in from the manufacturer and they were "not acceptable." Marshall now has to wait for them to be changed and resent for acceptance. I can get the current SCX version for anyone that needs gauges immediately. I am also going to be selling the CravenSpeed pods and adapters for 10% off of list for this group buy. Sorry for the delay.
Can you put me down for a Mechanical Boost gauge (that takes a vac line, right?)? Is there any idea on the cost?
Also, what would the flex pod cost for a car w/ Chrono/Nav?
Thanks!
The mechanical gauge connects via a vacuum line. Marshall hasn't set the price yet so I don't know. The mounting will cost more than the gauge. I am offering a 10% discount on the CravenSpeed flexpod mounts so one Z bracket (either side) would be $40 and the 52mm gauge cup would be $49. Thanks.
SRTech, you can put me down for a boost and water temp gauges. Also the cravenwood mounts. Type gauges, which ever is better, mechanical boost or stepper and stepper water temp. Chrome ring. I have a 09 JCW.
