Interior/Exterior Installing TVA armrest
Hi. I just received the TVA vinyl armrest for my MINI. It's a nice armrest, and it doesn't require any drilling to install. However, it didn't arrive with instructions, either. On the bottom of the armrest are two hook and latch mechanisms that need to go under the center plastic e-brake/cupholder console. Thing is, how do I remove the center e-brake/cupholder console? I don't see any screws? Do I just yank it up and off? Seems risky.
However, in order to correctly install the armrest, I need to remove the e-brake console, connect the armrest latches that secure it to the console, and reconnect the console.
Any advice appreciated!
Thanks,
Mighty_Boognish
You don't need to remove anything..... at least I didn't.
just push the bottom of the bracket into the space between the plastic console and the carpet. It won't hurt anything. Once you have the two brackets lined up, push them together at the top, and push the screw through. Finally screw the screws into the wooden part of the armrest.
Once you have everything all installed together, you can move the whole armrest forward or backward to your desired location. If you do a search, OctaneGuy has posted quite a few pictures; it should be able to help you figure out how to install it.
Thanks for the advice! Actually, I think you have the TVA "elbow landing device" right? The round mushroom looking one with the metal supports?
I bought the other one, the "long" padded, vinyl armrest (the $70 one). I figured out how to install it after fiddling around with it last night. Just as you do for the landing device: simply slide the 4 "hooks" between the carpet and the plastic -- the tension keeps them firmly in place. No removing of anything required! It looks good and offers good support for those especially long trips.
Rock On,
-MightyBoognish
Here's the big bulky one I bought...actually it's not as bulky as it looks in the photo: it fits right between the seats with about 1/2" inch clearance on either side (space between the armrest and the seats). Thing is, it only comes in grey, but it's a very dark grey, looks perfect with the black leatherette seats...
http://www.aiwana.com/Merchant/merch...y_Code=miniint
Here's a photo of the "elbow landing device:" (Someone on MCO, oops I mean NAM, has photos of this in his MINI..)
Rock ON,
-MightyBoognish
>>Thanks,
>>Mighty_Boognish
Here's the thread on this armrest that I created:
Elbow Landing Device on NAM
The pix were broken cause I modified the location of the pictures on my server, but it's fixed now. You can also find more info at:
Lil'Octane's Arm Rest Pictures
>>Thanks,
>>Mighty_Boognish
Originally Posted by Storer
You've got to be kidding me?! 50 bucks for that thing? Parts cost $15 TOPS! I would imagine about 7 minutes went into R&D. And people complain about $600 exhaust?
>>Thanks,
>>Mighty_Boognish
>>Thanks,
>>Mighty_Boognish
