Interior/Exterior instead of interior Chrome trim ring, anyone see a black one
gloss black trim rings would be wicked nice, i've been also looking around for these lately but have yet to come up with any results =/
edit: on second thought. you can always pull your trim rings out, and spray them/get them sprayed gloss black. will take time and effort but im sure the results will look fantastic. I'm actually considering doing this to match my piano black interior.
Speedo and 2 inner Air Vents (L165):
https://www.newministuff.com/new/sho...uctshow&id=648
2 outer Air Vents (L105):
https://www.newministuff.com/new/sho...uctshow&id=652
What is L270 in US$?
on
Don't see any Black, but I do see Carbon Fiber for the 2nd Gen Mini's.
on
That's my plan. I have the piano black trim and want to be rid of the lite grey trim rings. Doors should be easy enough but the dash ones are holding me back because of the time involved to pull the car apart. But I will be doing it and doing it myself. Proper cleaning and then painting with rattle can should make this achievable with a few coats of gloss clear coat to protect. Gloss black to match the piano black trim should look awesome. Only thing left will be the trim on the steering wheel and the HVAC/radio in that cheap-azz lite grey. The other option is plasti dip !!!
So what did you end up doing? My only hesitancy in ordering a MINI, was all the silver plastic in the interior. Of course, I've gotten over that and ordered one, but I still want to do something about all the silver plastic--all the little rings around the interior. Has anyone done anything with these pieces that you'd like to share?
on
I've pulled all my door rings out, 3 per door. They've been all spray painted gloss black and then gloss clear coat. The door handles I snapped back in place and they do look awesome. HOWEVER. The big however is in order to take out the speaker rings, you have to remove the hot melted tabs that hold them in place. In now looking at the rings, I'm wondering what to use to re-attach them back onto the door plastic so that one day I don't look down and the ring is gonzo because the adhesive let go.
Thoughts ???
Thoughts ???
Thoughts ???
Thoughts ???
I wouldn't think plasti-dip would look very nice on an interior part so prominent as the center speedo ring, since it's going to be textured and would clash with everything else.
07-16-2020 12:54 PM
minimaximum
R55 :: Clubman Talk (2008+)
08-14-2015 04:05 PM
