Interior/Exterior Bonnet stripe removal
The stripes can be removed by using a hair dryer to heat them up and then slowly peeling them off.
If they've been on for 19 months, though, I would imagine there is a possibility that the paint under the stripes could be slightly darker than the surrounding areas due to some fading. Can't say for sure. I've only had my car since August and removed my dealer stripes immediately.
Good luck! :smile:
Good luck! :smile:
3M makes a spray on remover that cuts through the vinyl and attacks the glues, making removal quite simple. However, make sure you mask off the rest of the hood as the stuff is kind of messy. It won't damage your paint and will remove the adhesive as well as the stripe - sometimes the heating method leaves the adhesives behind and getting it off can be a challedge. You can normally find it at NAPA dealers - "Woodgrain and Decal Remover" or something like that.
07-16-2020 12:54 PM
Drumsound
08-25-2015 02:25 PM
bctf1
08-06-2015 12:55 PM
