Interior/Exterior Rear Wiper Delete Problem
So i flipped up the rear wiper cap took off the nut, took off the wiper arm. The problem i have is taking off that metal sprayer nozzle. How do you remove this? I tried with pulling the nozzle pliers, my hands, wd-40 and it wouldnt come off, please help... Thanks
The 'metal sprayer nozzle' is actually part of the spindle, which is attached to the motor. You'll need to pull the whole motor out from the inside of the hatch. You can only do this once you've got the interior door panel off. Then it will obvious what you should remove. Should be 3 or so 10mm nuts holding it to the hatch.
ahh, now i get it thanks! how do you remove the panel?
07-16-2020 12:54 PM
