Interior/Exterior How to replace rear side marker bulb
You cannot pry off the lens. The bulb plugs in from the back. If you stick your head underneath you can see it. Otherise you'll need to unhook the back of the fender well but I am not sure that his necessary. There is a small detent on the bulb holder that needs to be pressed to release it.
But the important thing is that it gets replaced from the back, not the front.
Rich
Rich
pull rear arch away from body work (these are on clips),then unscrew the screw which holds the top part of the bumper arch then pull bumper arch away from bumper and voila rear marker light is then exposed ,twist bulb out of hoder and replace ,there is another screw under the bumper which holds the bottom of the bumper arch but i found i didnt need to unscrew that unless your removing the whole thing .
hope this helps and you understand my UK terminology
07-16-2020 12:54 PM
cm.d
08-19-2015 08:51 AM
Minibeagle
08-13-2015 10:00 AM
