Interior/Exterior Deleted my rear wiper! Woot
Old 03-17-2012, 05:23 AM
[insert name here]'s Avatar
[insert name here]
[insert name here] is offline
Originally Posted by NC TRACKRAT
Added suggestion: If you have or contemplate getting an ALTA Intercooler Air Diverter and want to use the water injector, then its a relatively simple matter to use a T-Tap at the passenger side cowl to supply the water that would normally go to the rear wiper. If you keep your rear wiper motor, a simple off-on toggle switch at the rear will disable it so that, when you crank the stalk to spray water, you'll get water at the intercooler but your rear wiper won't cycle. In hot weather, especially on-track, keeping your intercooler cool means more hp!
Awesome idea! I have heard of putting a bag of ice on top mount intercoolers, but this will definitely save space. My only issue, doesn't the rear washer use the same reservoir as the front ones? Washer fluid is necessary to prevent freezing, but is it a good idea to spray antifreeze into the intercooler? Doubt it hurts, but can not think why it would be good for it.
  #27
Old 03-17-2012, 02:56 PM
NC TRACKRAT's Avatar
NC TRACKRAT
NC TRACKRAT is online now
You're not going to be concerned about IC temps in freezing weather. This mod is of use during hot track duty. I just use a piece of hose and siphon out all the windshield washer fluid from the reservoir and then fill with distilled water.
  #28
Old 10-24-2015, 12:13 PM
rededge02's Avatar
rededge02
rededge02 is offline
A hillman 9/16 black nylon hole plug will work great....it will fit perfectly in the stock wiper bung. A little silicone sealant on the backside and voila!! A whopping .43 cents!!!
07-16-2020 12:54 PM
06BLKchrgd
GP Talk (2006)
02-14-2016 12:07 AM
PhoenixR61
Electrical
08-22-2015 05:33 PM
The_Kid
08-18-2015 06:50 PM
08-07-2015 08:02 AM
Quick Reply: Interior/Exterior Deleted my rear wiper! Woot
