Interior/Exterior Air/fuel mixture guage...anyone install one?
Ressurecting this thread. I'm planning on getting an Air/Fuel guage, and would like to know about hooking it up. The wiring and what not I shouls be able to handle, but I'm not sure about what comes with the guage. Does it come with a sensor of some sort or is that something that must be bought seperately? Also, where does that sensor get placed in order to read the Air/Fuel ratio?
The gauges are nothing more than a light show unless you buy a Wideband gauge. These gauges will use an O2 sensor similar to the ones your car's emissions system uses. Usually you add a bung to your exhaust piping and screw it in. Some aftermarket exhausts already have a bung for this purpose.
For Xmas, I gave my son a PLX DM-5 combo. What attracted me was the fact that I would not have to add a bung but replace the existing sensor and "share it" w/ the gauge and the ECU. The instructions are a little light explanation wise - at least for me (i.e. not the sharpest tool in the shed). It may make more sense to just add a bung and wire up as standalone.
I need help identifying the following wires on the ECU Harness -
1) 12V power
2) chassis GND
3) 02 heater power
4) 02 heater GND
5) 02 signal Input
Appreciate any help you can offer.
1) 12V power
2) chassis GND
3) 02 heater power
4) 02 heater GND
5) 02 signal Input
