What do you mean by "work with Connect"? From the description, it transmits data to your iOS device. I don't see where Connect fits in.
I've never used Connect, but I didn't think it was capable of mirroring everything displayed on your phone. I could be wrong.
Will what is on the device show up on my connect screen. Also will it read all the sensors? I have heard that some of the obd2 devices do not read or work on all cars.
I use the KIWI WiFi version, and it works with the iPhone quite well. You need to find a program to read the sensors (I use Rev2), and so far I haven't had to many problems.
Bluetooth is better but need to unplug if idle for a week. Wifi will drain the battery in 2 days.
I was under the impression that it turns itself off?
"The Kiwi 2 Wifi incorporates a new advanced power saving circuit, designed to shut off power to essential functions of the unit allowing the Kiwi 2 Wifi to be permanently installed in your vehicle without draining your vehicle's battery. After 5 minutes of inactivity, the Kiwi 2 Wifi automatically enters a low power sleep mode. To turn the unit back on, a simple press of the soft switch wakes the device back up."
